[SCM] PostGIS branch master updated. 3.5.0-474-gb66da5a3e
Fri Jul 18 01:05:51 PDT 2025
the project "PostGIS".
       via  b66da5a3e3c6402d4246ddddbc0da661b857995f (commit)
      from  43960094f99294a3e5e62bda1082b2a3a269984e (commit)
revisions in full, below.
commit b66da5a3e3c6402d4246ddddbc0da661b857995f
Author: Loïc Bartoletti <loic.bartoletti at oslandia.com>
Date:   Thu Jul 17 14:18:51 2025 +0200
    fix(SFCGAL): CG_Visibilty returns empty polygon if one input is empty
diff --git a/sfcgal/lwgeom_sfcgal.c b/sfcgal/lwgeom_sfcgal.c
index b50a10c43..cec862018 100644
--- a/sfcgal/lwgeom_sfcgal.c
+++ b/sfcgal/lwgeom_sfcgal.c
@@ -1202,6 +1202,17 @@ sfcgal_visibility_point(PG_FUNCTION_ARGS)
 	point = POSTGIS2SFCGALGeometry(input1);
 	PG_FREE_IF_COPY(input1, 1);
+#if POSTGIS_SFCGAL_VERSION < 20200
+	if (gserialized_is_empty(input0) || gserialized_is_empty(input1))
+		result = sfcgal_polygon_create();
+		output = SFCGALGeometry2POSTGIS(result, 0, srid);
+		sfcgal_geometry_delete(result);
+		PG_RETURN_POINTER(output);
+#endif
 	result = sfcgal_geometry_visibility_point(polygon, point);
 	sfcgal_geometry_delete(polygon);
 	sfcgal_geometry_delete(point);
@@ -1241,7 +1252,18 @@ sfcgal_visibility_segment(PG_FUNCTION_ARGS)
 	pointA = POSTGIS2SFCGALGeometry(input1);
 	pointB = POSTGIS2SFCGALGeometry(input2);
-	PG_FREE_IF_COPY(input1, 2);
+	PG_FREE_IF_COPY(input2, 2);
+	if (gserialized_is_empty(input0) || gserialized_is_empty(input1) || gserialized_is_empty(input2))
+#endif
 	result = sfcgal_geometry_visibility_segment(polygon, pointA, pointB);
diff --git a/sfcgal/regress/visibility.sql b/sfcgal/regress/visibility.sql
index 392bd40dd..621467574 100644
--- a/sfcgal/regress/visibility.sql
+++ b/sfcgal/regress/visibility.sql
@@ -2,3 +2,8 @@ SELECT 'Visibility point in polygon', ST_AsText(CG_Visibility('POLYGON((0.0 4.0,
 SELECT 'Visibility point in polygon with hole', ST_AsText(CG_Visibility('POLYGON((0.0 4.0,0.0 0.0,3.0 2.0,4.0 0.0,4.0 4.0,1.0 2.0,0.0 4.0),(0.2 1.8,0.9 1.8,0.7 1.2,0.2 1.8))', 'POINT(0.5 2.0)'), 2);
 SELECT 'Visibility segment in polygon', ST_AsText(CG_Visibility('POLYGON((0.0 4.0,0.0 0.0,3.0 2.0,4.0 0.0,4.0 4.0,1.0 2.0,0.0 4.0))', 'POINT(1.0 2.0)', 'POINT(4.0 4.0)'), 2);
 SELECT 'Visibility segment in polygon with hole', ST_AsText(CG_Visibility('POLYGON((1.0 2.0,12.0 3.0,19.0 -2.0,12.0 6.0,14.0 14.0,9.0 5.0,1.0 2.0),(8.0 3.0,8.0 4.0,10.0 3.0,8.0 3.0),(10.0 6.0,11.0 7.0,11.0 6.0,10.0 6.0))', 'POINT(19.0 -2.0)', 'POINT(12.0 6.0)'), 2);
+SELECT 'Visibility point empty polygon', ST_AsText(CG_Visibility(ST_GeomFromText('POLYGON EMPTY',4326), ST_Point(1,2,4326)));
+SELECT 'Visibility point empty point', ST_AsText(CG_Visibility(ST_GeomFromText('POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0))',4326), ST_GeomFromText('POINT EMPTY', 4326)));
+SELECT 'Visibility segment empty polygon', ST_AsText(CG_Visibility(ST_GeomFromText('POLYGON EMPTY',4326), ST_Point(1,2,4326) , ST_Point(1,2,4326)));
+SELECT 'Visibility segment empty pointA', ST_AsText(CG_Visibility(ST_GeomFromText('POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0))',4326), ST_GeomFromText('POINT EMPTY', 4326) , ST_Point(1,2,4326)));
+SELECT 'Visibility segment empty pointB', ST_AsText(CG_Visibility(ST_GeomFromText('POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0))',4326), ST_Point(1,2,4326), ST_GeomFromText('POINT EMPTY', 4326)));
diff --git a/sfcgal/regress/visibility_expected b/sfcgal/regress/visibility_expected
index b0bc3172b..753d7e8c6 100644
--- a/sfcgal/regress/visibility_expected
+++ b/sfcgal/regress/visibility_expected
@@ -2,3 +2,8 @@ Visibility point in polygon|POLYGON((3 2,1 2,0 4,0 0,3 2))
 Visibility point in polygon with hole|POLYGON((0 1.67,0.2 1.8,0.9 1.8,1.93 1.29,3 2,1 2,0 4,0 1.67))
 Visibility segment in polygon|POLYGON((4 0,4 4,1 2,0 1.33,0 0,3 2,4 0))
 Visibility segment in polygon with hole|POLYGON((19 -2,12 6,14 14,10.43 7.57,11 7,11 6,10 6,9.56 6,9 5,1 2,4.67 2.33,8 4,10 3,9.87 2.81,12 3,19 -2))
+Visibility point empty polygon|POLYGON EMPTY
+Visibility point empty point|POLYGON EMPTY
+Visibility segment empty polygon|POLYGON EMPTY
+Visibility segment empty pointA|POLYGON EMPTY
+Visibility segment empty pointB|POLYGON EMPTY
Summary of changes:
 sfcgal/lwgeom_sfcgal.c             | 24 +++++++++++++++++++++++-
 sfcgal/regress/visibility.sql      |  5 +++++
 sfcgal/regress/visibility_expected |  5 +++++
 3 files changed, 33 insertions(+), 1 deletion(-)
hooks/post-receive
