[SCM] PostGIS branch master updated. 3.5.0-475-g7c47c79c0
git at osgeo.org
git at osgeo.org
Fri Jul 18 20:43:44 PDT 2025
the project "PostGIS".
via 7c47c79c09b2e5a0bf7f8b0d7b5b2f0bc1484f86 (commit)
from b66da5a3e3c6402d4246ddddbc0da661b857995f (commit)
revisions in full, below.
commit 7c47c79c09b2e5a0bf7f8b0d7b5b2f0bc1484f86
Author: Regina Obe <lr at pcorp.us>
Date: Fri Jul 18 23:30:14 2025 -0400
PREPARE FOR 3.6.0beta1
- NEWS updates about GEOS / SFCGAL versions and topology deprecated signatures
- Make 18 latest supported
- Flip to 3.6.0beta1
diff --git a/NEWS b/NEWS
index 7a933102f..bbd545bfb 100644
--- a/NEWS
+++ b/NEWS
@@ -1,9 +1,9 @@
-PostGIS 3.6.0dev
+PostGIS 3.6.0beta1
2025/07/xx
-This version requires PostgreSQL 12-18beta1, GEOS 3.8 or higher, and Proj 6.1+.
-To take advantage of all features, GEOS 3.12+ is needed.
-To take advantage of all SFCGAL features, SFCGAL 2.1+ is needed.
+This version requires PostgreSQL 12-18beta2, GEOS 3.8 or higher, and Proj 6.1+.
+To take advantage of all features, GEOS 3.14+ is needed.
+To take advantage of all SFCGAL features, SFCGAL 2.2+ is needed.
Many thanks to our translation teams, in particular:
@@ -15,12 +15,16 @@ Dapeng Wang, Zuo Chenwei from HighGo (Chinese Team)
- #5799, make ST_TileEnvelope clips envelopes to tile plane extent (Paul Ramsey)
- #5829, remove constraint checking from geometry_columns view (Paul Ramsey)
- - #3373, GT-255 [topology] Support for upgrading domains (Ayo Adesugba, U.S. Census Bureau)
+ - #3373, GT-255, [topology] Support for upgrading domains (Ayo Adesugba, U.S. Census Bureau)
- GT-252, ST_NumGeometries/ST_GeometryN treat TIN and PolyhedralSurface as unitary geometries,
use ST_NumPatches/ST_PatchN for patch access (Loïc Bartoletti)
- #3110, GT-242 [topology] Support for bigint (Ayo Adesugba, U.S. Census Bureau)
-* Deprecated signatures *
+* Deprecated / Removed signatures *
+ - #3110, GT-242, [topology] numerous topology functions that accepted integer
+ replaced with bigint versions to support both integer and bigint inputs
+ (Ayo Adesugba, U.S. Census Bureau)
* New Features *
@@ -34,7 +38,7 @@ Dapeng Wang, Zuo Chenwei from HighGo (Chinese Team)
- #1247, [raster] ST_AsRasterAgg (Sandro Santilli)
- #5784, GT-223 Export circ_tree_distance_tree_internal for mobilitydb use
(Maxime Schoemans)
- - GT-228 [sfcgal] Add new functions (Scale, Translate, Rotate, Buffer 3D and
+ - GT-228, [sfcgal] Add new functions (Scale, Translate, Rotate, Buffer 3D and
Straight Skeleton Partition) from SFCGAL 2 (Loïc Bartoletti)
- [raster] New GUC postgis.gdal_cpl_debug, enables GDAL debugging messages
and routes them into the PostgreSQL logging system. (Paul Ramsey)
diff --git a/README.postgis b/README.postgis
index 135d4768b..7643c270d 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.6.0alpha1
-:Date: 2025-05-17
+:Version: 3.6.0beta1
+:Date: 2025-07-19
:Website: https://postgis.net
This distribution contains a module which implements GIS simple features, ties
@@ -65,6 +65,7 @@ For apt-based systems you can run this command to install the below dependencies
https://proj.org
* GEOS (Required, Version 3.8 or higher)
+ - 3.14+ for ST_CoverageClean
- 3.12+ for ST_CoverageSimplify and ST_CoverageInvalidEdges
- 3.11+ for improved ST_ConcaveHull, ST_lineMerge,
and new functions ST_SimplifyPolygonHull, ST_TriangulatePolygon
diff --git a/Version.config b/Version.config
index cf6d63e9f..fadb7a384 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
POSTGIS_MAJOR_VERSION=3
POSTGIS_MINOR_VERSION=6
-POSTGIS_MICRO_VERSION=0dev
+POSTGIS_MICRO_VERSION=0beta1
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
diff --git a/doc/installation.xml b/doc/installation.xml
index e690fb2c3..85bdfb3eb 100644
--- a/doc/installation.xml
+++ b/doc/installation.xml
@@ -144,7 +144,7 @@ sh autogen.sh
is available from
<link xlink:href="https://www.postgresql.org">
- </link>
+ </link>18
</para>
<para>For a full PostgreSQL / PostGIS support matrix and PostGIS/GEOS support matrix refer to
@@ -184,7 +184,7 @@ sh autogen.sh
<listitem>
<para>
- GEOS geometry library, version &min_geos_version; or greater, but GEOS 3.12+ is required to take full advantage of all the new functions and features. GEOS is available for download from
+ GEOS geometry library, version &min_geos_version; or greater, but GEOS 3.14+ is required to take full advantage of all the new functions and features. GEOS is available for download from
<link xlink:href="https://libgeos.org/">
https://libgeos.org
</link>.
diff --git a/doc/postgis.xml b/doc/postgis.xml
index 185df166d..77a4ead52 100644
--- a/doc/postgis.xml
+++ b/doc/postgis.xml
@@ -13,10 +13,10 @@
<!-- Change these values to update the version numbers referenced within the documentation -->
<!ENTITY last_proj_release_version "9.2.1">
-<!ENTITY last_geos_release_version "3.13.0">
+<!ENTITY last_geos_release_version "3.14.0">
<!ENTITY min_geos_version "3.8.0">
<!ENTITY min_postgres_version "12">
-<!ENTITY max_postgres_version "17">
+<!ENTITY max_postgres_version "18">
<!ENTITY introduction SYSTEM "introduction.xml">
<!ENTITY installation SYSTEM "installation.xml">
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 1b0faab56..5e03e9723 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -4,10 +4,10 @@
<subtitle>Release Notes</subtitle>
<section>
<title>PostGIS 3.6.0beta1</title>
- <para>2025/07/xx</para>
- <para>This version requires PostgreSQL 12-18beta1, GEOS 3.8 or higher, and Proj 6.1+.
- To take advantage of all features, GEOS 3.12+ is needed.
- To take advantage of all SFCGAL features, SFCGAL 2.1+ is needed.</para>
+ <para>2025/07/19</para>
+ <para>This version requires PostgreSQL 12-18beta2, GEOS 3.8 or higher, and Proj 6.1+.
+ To take advantage of all features, GEOS 3.14+ is needed.
+ To take advantage of all SFCGAL features, SFCGAL 2.2+ is needed.</para>
<para>Many thanks to our translation teams, in particular:</para>
<para>Teramoto Ikuhiro (Japanese Team)</para>
@@ -19,10 +19,14 @@
<simplesect><title>Breaking Changes</title>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5799">#5799</link>, make ST_TileEnvelope clips envelopes to tile plane extent (Paul Ramsey)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5829">#5829</link>, remove constraint checking from geometry_columns view (Paul Ramsey)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/3373">#3373</link>, <link xlink:href="https://git.osgeo.org/gitea/postgis/postgis/pulls/255">GT-255</link> [topology] Support for upgrading domains (Ayo Adesugba, U.S. Census Bureau)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/3373">#3373</link>, <link xlink:href="https://git.osgeo.org/gitea/postgis/postgis/pulls/255">GT-255</link>, [topology] Support for upgrading domains (Ayo Adesugba, U.S. Census Bureau)</para>
<para><link xlink:href="https://git.osgeo.org/gitea/postgis/postgis/pulls/252">GT-252</link>, ST_NumGeometries/ST_GeometryN treat TIN and PolyhedralSurface as unitary geometries,
use ST_NumPatches/ST_PatchN for patch access (Loïc Bartoletti)</para>
- <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/3110">#3110</link>, <link xlink:href="https://git.osgeo.org/gitea/postgis/postgis/pulls/242">GT-242</link> [topology] Support for bigint (Ayo Adesugba, U.S. Census Bureau)</para>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/3110">#3110</link>, <link xlink:href="https://git.osgeo.org/gitea/postgis/postgis/pulls/242">GT-242</link>, [topology] Support for bigint (Ayo Adesugba, U.S. Census Bureau)</para>
+ </simplesect>
+ <simplesect><title>Removed / Deprecate signatures</title>
</simplesect>
<simplesect><title>New Features</title>
@@ -43,7 +47,7 @@
<para>Add ST_CoverageClean to edge match and gap remove polygonal
coverages (Paul Ramsey) from GEOS 3.14 (Martin Davis)</para>
<para>Add ST_ReclassExact to quickly remap values in raster (Paul Ramsey)</para>
</simplesect>
</section>
</appendix>
Summary of changes:
NEWS | 18 +++++++++++-------
README.postgis | 5 +++--
Version.config | 2 +-
doc/installation.xml | 4 ++--
doc/postgis.xml | 4 ++--
doc/release_notes.xml | 18 +++++++++++-------
6 files changed, 30 insertions(+), 21 deletions(-)
hooks/post-receive
