[PostGIS] #5903: topology/test/regress/topogeo_addlinestring test_224_out: ERROR: index returned tuples in wrong order
PostGIS trac at osgeo.org
Tue Jul 22 08:14:40 PDT 2025
  Reporter:  Christoph Berg  |      Owner:  strk
      Type:  defect          |     Status:  new
  Priority:  high            |  Milestone:  PostGIS 3.5.4
 Component:  topology        |    Version:  3.5.x
Resolution:                  |   Keywords:
Comment (by Christoph Berg):
 It's currently the oldest one, yes (focal was already dropped earlier). It
 did work with PostGIS 3.5.2, and I don't think the rest of the GIS stack
 in bullseye was changed in between.
 (The "was the order by accurate" check is from 2015, so no change in PG
 either.)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5903#comment:8>
