[PostGIS] #5951: server process was terminated by signal 11: Segmentation fault, postgis topology
trac at osgeo.org
Wed Jul 23 23:44:02 PDT 2025
topology
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.0
Component: topology | Version: master
Keywords: |
When running overlay for all Norway I got a problem in one area that
always cases the postgreSQL to core dump.
I am running on
PostgreSQL 16.4 (Ubuntu 16.4-1.pgdg22.04+1) on x86_64-pc-linux-gnu,
compiled by gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, 64-bit
(1 row)
POSTGIS="3.6.0beta1 3.6.0beta1-4-g1458a794d" [EXTENSION] PGSQL="160"
GEOS="3.13.1-CAPI-1.19.2" PROJ="9.3.0 NETWORK_ENABLED=OFF
URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/tmp/proj
DATABASE_PATH=/usr/local/share/proj/proj.db" (compiled against PROJ 9.3.0)
LIBXML="2.9.13" LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
(Internal)" TOPOLOGY
In the logs I see this
< pid 46085, 6881cfdb.b405 , , , , 2025-07-24 08:17:47.768 CEST >DEBUG:
server process (PID 46114) was terminated by signal 11: Segmentation fault
< pid 46085, 6881cfdb.b405 , , , , 2025-07-24 08:17:47.768 CEST >LOG:
terminating any other active server processes
sending SIGQUIT to process 46094
sending SIGQUIT to process 46112
sending SIGQUIT to process 46111
sending SIGQUIT to process 46110
sending SIGQUIT to process 46090
sending SIGQUIT to process 46089
sending SIGQUIT to process 46092
sending SIGQUIT to process 46093
reaping dead processes
< pid 46085, 6881cfdb.b405 , , , , 2025-07-24 08:17:47.770 CEST >DEBUG:
< pid 46085, 6881cfdb.b405 , , , , 2025-07-24 08:17:47.771 CEST >DEBUG:
< pid 46085, 6881cfdb.b405 , , , , 2025-07-24 08:17:47.772 CEST >DEBUG:
server process (PID 46110) exited with exit code 2
server process (PID 46111) exited with exit code 2
< pid 46085, 6881cfdb.b405 , , , , 2025-07-24 08:17:47.784 CEST >DEBUG:
server process (PID 46112) exited with exit code 2
This last logs from pid 46114
< pid 46114, 6881cfe6.b422 , [local], postgres, rog_02, 2025-07-24
08:17:47.732 CEST >DEBUG: building index "pg_toast_1067768161_index" on
table "pg_toast_1067768161" serially
08:17:47.732 CEST >STATEMENT: CALL resolve_overlap_gap_single_cell(
E'{"(,id,geo,sk_grl.n5_forvaltning_flate,kom,sl_sdeid,geo,4258,f,\\"id
integer\\",id,\\"komid integer,objekttype character varying,fylkeid
integer,fylkenavn character varying,kommunenavn character varying,knr
character,utmsone integer,sl_sdeid integer,geo_nr
smallint\\",\\"komid,objekttype,fylkeid,fylkenavn,kommunenavn,knr,utmsone,
sl_sdeid,geo_nr\\")","(,,,org_arealregnskap.ssbarealbruk_hav_treslag_kystsone_diss_rydda,ark,id,geo,4258,f,,,,)"}','{"(1,sk_grl.n5_forvaltning_flate,sl_sdeid,integer,kom,geo,,4258,f)","(2,org_arealregnskap.ssbarealbruk_hav_treslag_kystsone_diss_rydda,id,integer,ark,geo,,4258,f)"}','(grunnkart_03.rydd_v3,grunnkart_03_topo_error,4258,f,0,t,1,2,t,t,3
)',1e-07,'grunnkart_03_topo_error.rydd_v3',
'(2,0,t,,0,0,0,0,0,0,0,0103000020A210000001000000050000000EF7987969EE204070478FBDF5824D400EF7987969EE2040F415B7C4A9844D408EE779C13FFC2040F415B7C4A9844D408EE779C13FFC204070478FBDF5824D400EF7987969EE204070478FBDF5824D40,1.1889460856827504e-06,)',
'grunnkart_03_topo_error.rydd_v3_job_list','grunnkart_03_topo_error.rydd_v3_grid','0103000020A210000001000000050000000EF7987969EE204070478FBDF5824D400EF7987969EE2040F415B7C4A9844D408EE779C13FFC2040F415B7C4A9844D408EE779C13FFC204070478FBDF5824D400EF7987969EE204070478FBDF5824D40',1,1);
--jobid=1
08:17:47.732 CEST >DEBUG: index "pg_toast_1067768161_index" can safely
use deduplication
smallint\\",\\"komid,objekttype,fylkeid,fylkenavn,kommunenavn,knr,utmsone,sl_sdeid,geo_nr\\")","(,,,org_arealregnskap.ssbarealbruk_hav_treslag_kystsone_diss_rydda,ark,id,geo,4258,f,,,,)"}','{"(1,sk_grl.n5_forvaltning_flate,sl_sdeid,integer,kom,geo,,4258,f)","(2,org_arealregnskap.ssbarealbruk_hav_treslag_kystsone_diss_rydda,id,integer,ark,geo,,4258,f)"}','(grunnkart_03.rydd_v3,grunnkart_03_topo_error,4258,f,0,t,1,2,t,t,3)',1e-07,'grunnkart_03_topo_error.rydd_v3',
--jobid=1
I am using code from code from https://gitlab.com/nibioopensource/resolve-
overlap-and-gap and run command which involve a big data dataset with a
lot of gaps and tiny overlap
PostgresSQL core everytime after about a minute when I run the command
below.
CALL topo_rog_static.rog_overlay(
ARRAY[
'sk_grl.n5_forvaltning_flate kom',
'org_arealregnskap.ssbarealbruk_hav_treslag_kystsone_diss_rydda ark'
'grunnkart_03.rydd_v3',
4258, --srid GRADER
0, -- no snapto, SKAL IKKE ENDRES 1e-06
2, -- min m2 area to keep
0, -- split all lines at given vertex num
true, -- _break_up_big_polygons
0.1, -- min negative buffer value null,
remove sliver polygons
ARRAY[('0103000020A210000001000000050000000EF7987969EE204070478FBDF5824D400EF7987969EE2040F415B7C4A9844D408EE779C13FFC2040F415B7C4A9844D408EE779C13FFC204070478FBDF5824D400EF7987969EE204070478FBDF5824D40','topo_error')::rog_input_boundary::rog_input_boundary],
true, -- do_qualitycheck_on_final_reseult
-- Method 3 select from tmp toplogy into
master topology
3,
1, -- _max_parallel_jobs int, -- this is
the max number of paralell jobs to run. There must be at least the same
number of free cinnections
500, -- _max_rows_in_each_cell int, --
this is the max number rows that intersects with box before it's split
into 4 new boxes
null,
NULL
I am working on test files to reproduce this error but happens after
adding lines and then remove and after add some new lines .
I hard to reproduce because depending on data input the results behaves
different if I wrap for TopoGeo_addLinestring into a procedure or not.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5951>
