[PostGIS] #5951: server process was terminated by signal 11: Segmentation fault, postgis topology
PostGIS trac at osgeo.org
Thu Jul 24 05:01:40 PDT 2025
topology
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  defect             |     Status:  new
  Priority:  medium             |  Milestone:  PostGIS 3.6.0
 Component:  topology           |    Version:  master
Resolution:                     |   Keywords:
Comment (by Lars Aksel Opsahl):
 After running test_01.sql postgresql core dumps after this set off SQL's
 CREATE table grunnkart_03_topo_error_1_small_all_1_2 AS
         SELECT
         s.edge_id,
         s.face_id,
         s.face_area,
         s.table_input_order,
         s.edge_geoms
         FROM
                                         SELECT
                                         unnest(edge_ids) edge_id, -- the
 list of edges around the face
                                         face_area,
                                         face_id,
                                         table_input_order,
                                         edge_geoms
                                         FROM
 unnest('{"({630},-1,8,-1,)","({630},-1,8,-1,)","({633},-1,38,-1,)","({636},-1,300,-1,)","({636},-1,300,-1,)","({639},-1,39,-1,)","({639},-1,301,-1,)","({639},-1,39,-1,)","({639},-1,301,-1,)","({642},-1,157,-1,)","({642},-1,157,-1,)","({645},-1,303,-1,)","({645},-1,303,-1,)","({648},-1,304,-1,)","({648},-1,304,-1,)","({651},-1,305,-1,)","({651},-1,305,-1,)","({654},-1,306,-1,)","({654},-1,306,-1,)","({657},-1,307,-1,)","({657},-1,307,-1,)","({660},-1,308,-1,)","({663},-1,309,-1,)","({663},-1,309,-1,)","({666},-1,261,-1,)","({666},-1,310,-1,)","({666},-1,261,-1,)","({666},-1,310,-1,)","({669},-1,310,-1,)","({669},-1,310,-1,)","({672},-1,159,-1,)","({672},-1,159,-1,)","({675},-1,313,-1,)","({675},-1,314,-1,)","({675},-1,313,-1,)","({675},-1,314,-1,)","({678},-1,314,-1,)","({678},-1,314,-1,)","({681},-1,313,-1,)","({681},-1,315,-1,)","({681},-1,313,-1,)","({681},-1,315,-1,)","({684},-1,316,-1,)","({684},-1,316,-1,)","({687},-1,317,-1,)","({687},-1,317,-1,)","({690},-1,193,-1,)","({690},-1,193,-1,)","({693},-1,319,-1,)","({693},-1,319,-1,)","({695},-1,39,-1,)","({698},-1,191,-1,)","({698},-1,191,-1,)","({701},-1,292,-1,)","({701},-1,292,-1,)","({704},-1,323,-1,)"}'::add_border_lines_faces_to_remove[])
         ) s;
         CREATE INDEX ON grunnkart_03_topo_error_1_small_all_1_2
 (table_input_order);
         CREATE INDEX ON grunnkart_03_topo_error_1_small_all_1_2 (edge_id);
         CREATE INDEX ON grunnkart_03_topo_error_1_small_all_1_2 (face_id);
         ANALYZE grunnkart_03_topo_error_1_small_all_1_2;
 CREATE table grunnkart_03_topo_error_1_small_selected_1_2 AS
 WITH unique_face_id AS (
                                 SELECT
                                 table_input_order min_table_input_order,
                                 face_id,
                                 edge_id
                                 FROM
                                 GROUP BY table_input_order, face_id,
 edge_id
                                 ORDER BY table_input_order, face_id,
 edge_id
 edge_delete_short AS (
                                 SELECT
 abs((topology.ST_GetFaceEdges('grunnkart_03_topo_error_1',eshort.face_id)).edge)
 edge_id,
                                 face_id,
                                 min_table_input_order table_input_order
                                 FROM
                                 unique_face_id eshort
                                 WHERE eshort.min_table_input_order = -1
 new_edge_delete_short AS (
                                 SELECT
                                 sh.face_id,
                                 sh.edge_id,
                                 e.left_face,
                                 e.right_face,
                                 1000 table_input_order,
                                 CASE when e.left_face = 0 OR e.right_face
 = 0 then 1
                                 ELSE 0
                                 END AS outer_face_edge,
                                 CASE when e.left_face > 1 AND e.right_face
 > 1 then 1
                                 ELSE 0
                                 END AS inner_face_edge,
                                 e.geom
                                 FROM
                                 edge_delete_short sh,
                                 grunnkart_03_topo_error_1.edge_data e
                                 WHERE e.edge_id = sh.edge_id AND
                                 NOT EXISTS ( SELECT TRUE FROM
 unique_face_id ee WHERE sh.edge_id = ee.edge_id AND
 ee.min_table_input_order = -1)
 new_edge_delete_other AS (
                                 SELECT
                                 ot.face_id,
                                 ot.edge_id,
                                 e.left_face,
                                 e.right_face,
                                 ot.table_input_order,
                                 CASE when e.left_face = 0 OR right_face =
 0 then 1
                                 ELSE 0
                                 CASE when e.left_face > 0 AND right_face >
 0 then 1
                                 ELSE 0
                                 e.geom
                                 FROM
 ot,
                                 WHERE ot.table_input_order > -1 AND
 e.edge_id = ot.edge_id AND
                                 (e.left_face = ot.face_id OR e.right_face
 = ot.face_id)
 edges_to_delete AS (
                                 SELECT face_id,edge_id,table_input_order,
 outer_face_edge, inner_face_edge, geom, left_face, right_face
                                 FROM new_edge_delete_short
                                 UNION ALL
                                 SELECT
 face_id,edge_id,table_input_order,outer_face_edge,inner_face_edge, geom,
                                 FROM new_edge_delete_other
 distinct_face_id AS (
                                 SELECT DISTINCT ON (ed.face_id)
 ed.face_id, ed.left_face, ed.right_face,
 ed.table_input_order,ed.inner_face_edge, ed.outer_face_edge, ed.edge_id,
 ed.geom
                                 FROM edges_to_delete ed
                                 ORDER BY ed.face_id desc,
 ed.table_input_order desc, ed.outer_face_edge, ed.inner_face_edge,
 ST_Length(ed.geom,true) desc
 SELECT DISTINCT ON (ed.edge_id)
 ed.face_id,
 ed.left_face,
 ed.right_face,
 ed.inner_face_edge,
 ed.outer_face_edge,
 ed.edge_id, ed.geom,
 CASE WHEN (ed.left_face > 0 AND ed.right_face > 0) ANd ed.left_face !=
 ed.right_face THEN TRUE
 ELSE FALSE END AS is_ok_now
 FROM distinct_face_id ed
 ORDER BY ed.edge_id desc, ed.table_input_order desc, ed.outer_face_edge,
 ed.inner_face_edge , ed.face_id desc, ST_Length(ed.geom,true) desc;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5951#comment:2>
