[PostGIS] #5951: server process was terminated by signal 11: Segmentation fault, postgis topology
trac at osgeo.org
Thu Jul 24 07:39:48 PDT 2025
topology
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 3.6.0
Component: topology | Version: master
Resolution: | Keywords:
Comment (by strk):
Sourcing the test_01.sql file you attached does not result in a segfault
for me, on this:
> POSTGIS="3.6.0beta1 3.6.0beta1-4-g1458a794d" PGSQL="150" GEOS="3.14
.0dev-CAPI-1.20.0" PROJ="9.1.1 NETWORK_ENABLED=OFF
URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/tmp/proj
DATABASE_PATH=/usr/share/proj/proj.db" (compiled against PROJ 9.1.1)
LIBXML="2.9.14" LIBJSON="0.16" LIBPROTOBUF="1.4.1" WAGYU="0.5.0
(Internal)" TOPOLOGY
Can you get a stacktrace ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5951#comment:6>
