[PostGIS] #5951: server process was terminated by signal 11: Segmentation fault, postgis topology
trac at osgeo.org
Fri Jul 25 00:28:59 PDT 2025
topology
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 3.6.0
Component: topology | Version: master
Resolution: | Keywords:
Comment (by strk):
I've found the problem (SRF state not initialized and not checked on
second iteration) but it's tricky to write a regress test for it as the
crash ONLY occurs when the query affects multiple rows.
For example, this crashes the backend:
> select ST_GetFaceEdges('grunnkart_03_topo_error_1', face_id) from
grunnkart_03_topo_error_1.face where face_id > 260 and face_id < 280;
While neither of these do:
grunnkart_03_topo_error_1.face where face_id > 260 and face_id < 270;
grunnkart_03_topo_error_1.face where face_id >= 270 and face_id < 280
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5951#comment:11>
