[PostGIS] #5951: server process was terminated by signal 11: Segmentation fault, postgis topology
PostGIS trac at osgeo.org
Fri Jul 25 00:54:34 PDT 2025
topology
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  defect             |     Status:  assigned
  Priority:  blocker            |  Milestone:  PostGIS 3.0.12
 Component:  topology           |    Version:  3.0.x
Resolution:                     |   Keywords:
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"643ab10904f47dce8ea6f327d891289877e5a03d/git" 643ab10/git]:
 {{{#!CommitTicketReference repository="git"
 revision="643ab10904f47dce8ea6f327d891289877e5a03d"
 Fix crash in ST_GetFaceEdges with corrupted topology
 References #5951 in 3.4 branch (3.4.5dev)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5951#comment:16>
