[SCM] PostGIS branch stable-3.2 updated. 3.2.7-48-g8c4c2abfb
Fri Jul 25 01:35:13 PDT 2025
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  8c4c2abfb225f16fecfcc8d6e7749945a257aeac (commit)
      from  16a2ac1ad850b3d953878741aa1bc3ae790c59e9 (commit)
revisions in full, below.
commit 8c4c2abfb225f16fecfcc8d6e7749945a257aeac
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Jul 25 09:37:39 2025 +0200
    Fix crash in ST_GetFaceEdges with corrupted topology
    References #5951 in 3.2 branch (3.2.9dev)
    Includes regress test
diff --git a/NEWS b/NEWS
index 5761d39f0..3d64558e1 100644
--- a/NEWS
+++ b/NEWS
@@ -6,6 +6,7 @@ Proj 4.9+ required.
 * Bug Fixes  *
+ - #5951, [topology] Fix crash in ST_GetFaceEdges with corrupted topology (Sandro Santilli)
  - #5947, [topology] Fix crash in ST_ModEdgeHeal (Sandro Santilli)
  - #5925, #5946, [topology] Have GetFaceContainingPoint survive EMPTY edges (Sandro Santilli)
  - #5922, [topology] Fix crash in TopoGeo_AddLinestring with EMPTY input (Sandro Santilli)
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index 8a52e6d53..88817eac1 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -3122,6 +3122,8 @@ lwt_GetFaceEdges(LWT_TOPOLOGY* topo, LWT_ELEMID face_id, LWT_ELEMID **out )
     /* _lwt_FaceByEdges should have already invoked lwerror in this case */
     _lwt_release_edges(edges, numfaceedges);
+    lwerror("Corrupted topology: unable to build geometry of face %"
+      LWTFMT_ELEMID " from its %"PRIu64" edges", face_id, numfaceedges);
     return -1;
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index 2379463ad..8d608564a 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -4104,6 +4104,10 @@ Datum ST_GetFaceEdges(PG_FUNCTION_ARGS)
   /* get state */
   state = funcctx->user_fctx;
+  if ( ! state )
+    SRF_RETURN_DONE(funcctx);
   if ( state->curr == state->nelems )
diff --git a/topology/test/regress/st_getfaceedges.sql b/topology/test/regress/st_getfaceedges.sql
index 6ff65b468..356ba1faf 100644
--- a/topology/test/regress/st_getfaceedges.sql
+++ b/topology/test/regress/st_getfaceedges.sql
@@ -41,4 +41,15 @@ SELECT '#3265.3', 'E'||topology.TopoGeo_addLinestring('tt',
 SELECT '#3265.4', 0, ST_GetFaceEdges('tt', 0);
 SELECT '#3265.5', 1, ST_GetFaceEdges('tt', 1);
 SELECT '#3265.6', 2, ST_GetFaceEdges('tt', 2);
-SELECT topology.DropTopology('tt');
+SELECT NULL FROM topology.DropTopology('tt');
+-- See https://trac.osgeo.org/postgis/ticket/5951
+SELECT NULL FROM topology.CreateTopology('t5951');
+SELECT NULL FROM topology.TopoGeo_addLinestring('t5951', 'LINESTRING(0 0, 10 0)');
+SELECT NULL FROM topology.TopoGeo_addLinestring('t5951', 'LINESTRING(0 0, 5 5)');
+SELECT NULL FROM topology.TopoGeo_addLinestring('t5951', 'LINESTRING(5 5, 10 0)');
+SELECT NULL FROM topology.TopoGeo_addLinestring('t5951', 'LINESTRING(5 5, 10 5)');
+SELECT NULL FROM topology.TopoGeo_addLinestring('t5951', 'LINESTRING(10 0, 10 5)');
+UPDATE t5951.edge_data SET left_face = 0, right_face = 0 WHERE edge_id = 3;
+SELECT '#5951.1', topology.ST_GetFaceEdges('t5951', face_id) FROM t5951.face WHERE face_id > 0;
+SELECT NULL FROM topology.DropTopology('t5951');
diff --git a/topology/test/regress/st_getfaceedges_expected b/topology/test/regress/st_getfaceedges_expected
index 08d619f6f..e4c929206 100644
--- a/topology/test/regress/st_getfaceedges_expected
+++ b/topology/test/regress/st_getfaceedges_expected
@@ -38,4 +38,4 @@ t
 #3265.6|2|(1,1)
 #3265.6|2|(2,-2)
 #3265.6|2|(3,3)
-Topology 'tt' dropped
+ERROR:  Corrupted topology: unable to build geometry of face 1 from its 2 edges
Summary of changes:
 NEWS                                           |  1 +
 liblwgeom/lwgeom_topo.c                        |  2 ++
 topology/postgis_topology.c                    |  4 ++++
 topology/test/regress/st_getfaceedges.sql      | 13 ++++++++++++-
 topology/test/regress/st_getfaceedges_expected |  2 +-
 5 files changed, 20 insertions(+), 2 deletions(-)
hooks/post-receive
