[PostGIS] #5404: debbie failing on tickets regress ST_Intersection PostGIS 3.1, PostGIS 3.2, GEOS 3.9, GEOS 3.10 branch
PostGIS trac at osgeo.org
Fri Jul 25 02:47:02 PDT 2025
  Reporter:  robe          |      Owner:  robe
      Type:  defect        |     Status:  closed
  Priority:  blocker       |  Milestone:  PostGIS 3.1.10
 Component:  QA/buildbots  |    Version:  3.1.x
Resolution:  fixed         |   Keywords:
Comment (by strk):
 Maybe we should have kept the tests and massage the exception error
 message but oh well... I've backported to 3.0 too as Woodie was otherwise
 failing now that it uses a newer GEOS
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5404#comment:8>
