[PostGIS] #5955: ST_GetFaceGeometry eats our ram
PostGIS trac at osgeo.org
Fri Jul 25 11:10:45 PDT 2025
  Reporter:  latot     |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  high      |  Milestone:  PostGIS 3.5.4
 Component:  topology  |    Version:  3.5.x
Resolution:            |   Keywords:
Description changed by latot:
Old description:
> Hi! we know from some time in some circunstances there was something off,
> what was missing is a reprex to find this.
> Here is! how to cause the whole session use all the ram:
> SELECT
>         topology.createtopology (
>                 'overflow',
>                 0,
>                 0
> SELECT TopoGeo_AddPolygon(
>         'overflow',
>         'POLYGON((0 0, 0 1, 1 1, 0 0))'::geometry,
>         0
> DO $$
> DECLARE
>  face GEOMETRY;
> BEGIN
>         LOOP
>                 face := (topology.ST_GetFaceGeometry('overflow', 1));
>                 RAISE NOTICE 'run';
>         END LOOP;
> END;
> With grayshde we did some tests, this is the most simple scenario, the
> ram will slowly increase, never being free....
> There is other circunstances, in some queries even running this function
> will not trigger this behavior, something closer that still would be good
> to keep an eye would be this scenario:
> DO $$
> DECLARE
>  geom GEOMETRY;
>  face GEOMETRY;
>  inter GEOMETRY;
> BEGIN
>         geom := 'SRID=0;POLYGON EMPTY'::GEOMETRY;
>         LOOP
>                 inter := ST_Intersection(geom, face);
>                 RAISE NOTICE 'run';
>         END LOOP;
> END;
> There is some very weird things with this, I hope with this simple cases
> we can finally start looking what happens behind.
> I have other complex queries that also needs some data to be executed,
> where any change causes to this do not happen.
> For the record:
> CREATE OR REPLACE FUNCTION dumppolygons (in_geom geometry) returns TABLE
> (path INT, geom geometry) language plpgsql AS $$
> BEGIN
>         IF GeometryType(in_geom) <> 'MULTIPOLYGON' THEN
>                 RAISE EXCEPTION 'geom is not a multipolygon';
>         END IF;
>         RETURN QUERY SELECT x.path[1], x.geom
>                 FROM (SELECT (ST_Dump(in_geom)).*) x;
>         IF NOT FOUND THEN
>                 RAISE EXCEPTION 'No geometries!';
>         END IF;
>         RETURN;
> END;
> DO $$
> DECLARE
>  a INT;
> BEGIN
> LOOP
> a := (
>         WITH faces AS (
>         SELECT
>                 x.face,
>                 topology.ST_GetFaceGeometry('manzana_urbana_topo',
> x.face[1]) geom
>         FROM (
>                 SELECT
> topology.GetTopoGeomElements('(1,1,190137,3)'::TopoGeometry) face
>         ) x
>         inter AS (
>                 SELECT dp.path, faces.face, ST_Intersection(faces.geom,
> dp.geom) area
>                 FROM faces,
> dumppolygons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
> dp
>         SELECT COUNT(1) counter
>         FROM (
>                 SELECT
>                 FROM inter
> RAISE NOTICE 'run';
> END LOOP;
> END;
> With this data:
> https://drive.google.com/file/d/14oF1eBqTVm01ETuXIfDugnK62g1NYxvB/view?usp=sharing
> What is weird here is... if you replace the function DumpPolygons with
> ST_Dump stops working, any change I tested there also make the reprex do
> not works.
> So now we have the simple example, and the complex one!
New description:
 SELECT
                 'overflow',
                 0,
                 0
         'overflow',
         0
 DO $$
 DECLARE
  face GEOMETRY;
 BEGIN
         LOOP
                 RAISE NOTICE 'run';
         END LOOP;
 END;
 With grayshde we did some tests, this is the most simple scenario, the ram
 DO $$
 DECLARE
  geom GEOMETRY;
  face GEOMETRY;
  inter GEOMETRY;
 BEGIN
         LOOP
                 RAISE NOTICE 'run';
         END LOOP;
 END;
 For the record:
 BEGIN
         END IF;
         IF NOT FOUND THEN
         END IF;
         RETURN;
 END;
 DO $$
 DECLARE
  a INT;
 BEGIN
 LOOP
 a := (
         WITH faces AS (
         SELECT
                 x.face,
 x.face[1]) geom
         FROM (
                 SELECT
         ) x
         inter AS (
 dp.geom) area
                 FROM faces,
 dp
         FROM (
                 SELECT
                 FROM inter
 RAISE NOTICE 'run';
 END LOOP;
 END;
 With this data:
 pgtopo_import -f manzna_urbana_topo.topo manzana_urbana_topo | psql
 not works.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5955#comment:2>
