[PostGIS] #5951: server process was terminated by signal 11: Segmentation fault, postgis topology
trac at osgeo.org
Fri Jul 25 23:43:05 PDT 2025
topology
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 3.0.12
Component: topology | Version: 3.0.x
Resolution: fixed | Keywords:
Comment (by Lars Aksel Opsahl):
Thanks, tested new code and it does not core dump any more
topology.ST_GetFaceEdges now throws a topology error I assume I then have
to wrap that into try catch to avoid the function to break and just log
the error.
Should I report the topology errors in a new issue ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5951#comment:21>
