[PostGIS] #5956: winnie failing on topology regress
trac at osgeo.org
Sun Jul 27 20:36:31 PDT 2025
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.6.0
Component: topology | Version: master
Resolution: | Keywords:
Old description:
> -------------- Dependencies --------------
> GEOS config: /projects/geos/rel-3.14w64gcc81/bin/geos-config
> GEOS version: 3.14.0beta1 (31400)
> GDAL config: /projects/gdal/rel-3.9.2w64gcc81/bin/gdal-config
> GDAL version: 3.9.2 (30902)
> SFCGAL config: /projects/CGAL/rel-sfcgal-1.5.2w64gcc81/bin
> /sfcgal-config
> SFCGAL version: 1.5.2
> PostgreSQL config:
> /projects/postgresql/rel/pg17w64gcc81/bin/pg_config
> PostgreSQL version: PostgreSQL 17.4
> PROJ version: 8.2.1 (80201)
> Libxml2 config: /projects/libxml/rel-
> libxml2-2.12.5w64gcc81/bin/xml2-config
> Libxml2 version: 2.12.5
> JSON-C support: yes
> protobuf support: yes
> protobuf-c version: 1002001
> PCRE support: Version 1
> Perl: /usr/bin/perl
> --------------- Extensions ---------------
> PostgreSQL EXTENSION support: enabled
> PostGIS Raster: enabled
> PostGIS Topology: enabled
> SFCGAL support: enabled
> Address Standardizer support: enabled
> -------- Documentation Generation --------
> xsltproc: /projects/xsltproc/xsltproc
> docbook xsl base:
> dblatex:
> convert: /c/Windows/System32/convert
> ./topology/test/regress/st_getfaceedges .. failed (diff expected
> obtained:
> /projects/postgis/tmp/3.6.0dev_pg17_geos3.14_gdal3.9.2w64/test_217_diff)
> --- ./topology/test/regress/st_getfaceedges_expected 2025-07-25
> 05:11:03.041875900 -0400
> /projects/postgis/tmp/3.6.0dev_pg17_geos3.14_gdal3.9.2w64/test_217_out
> 2025-07-27 23:04:03.950850000 -0400
> @@ -38,4 +38,4 @@
> #3265.6|2|(1,1)
> #3265.6|2|(2,-2)
> #3265.6|2|(3,3)
> -ERROR: Corrupted topology: unable to build geometry of face 1 from its
> 2 edges
> +ERROR: Corrupted topology: unable to build geometry of face 1 from its
> I haven't been paying attentions so not sure how long this has been going
> on. Perhaps a regex issue?
New description:
/sfcgal-config
PostgreSQL config:
JSON-C support: yes
Perl: /usr/bin/perl
docbook xsl base:
dblatex:
obtained:
+++ /projects/postgis/tmp/3.6.0dev_pg17_geos3.14_gdal3.9.2w64/test_217_out
@@ -38,4 +38,4 @@
#3265.6|2|(1,1)
#3265.6|2|(2,-2)
#3265.6|2|(3,3)
-ERROR: Corrupted topology: unable to build geometry of face 1 from its 2
edges
Comment (by robe):
Looks like it broke with this commit [bac95532/git]
I guess numfaceedges must be returning blank or something in windows.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5956#comment:1>
