[PostGIS] #5955: ST_GetFaceGeometry eats our ram
trac at osgeo.org
Mon Jul 28 23:22:33 PDT 2025
Reporter: latot | Owner: strk
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.5.4
Component: topology | Version: 3.5.x
Resolution: | Keywords:
Comment (by lnicola):
@latot FWIW, I ran your test case (the one calling
{{{TopoGeo_AddPolygon}}}) with my proposed patch and it didn't crash, the
memory usage stays unchanged and the tests still pass (except the raster
ones which I disabled because they use a wrong path even after {{{make
distclean}}}.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5955#comment:4>
