[PostGIS] #5956: winnie failing on topology regress
trac at osgeo.org
Tue Jul 29 07:53:29 PDT 2025
Reporter: robe | Owner: strk
Type: defect | Status: reopened
Priority: blocker | Milestone: PostGIS 3.6.0
Component: QA/buildbots | Version: master
Resolution: | Keywords:
Changes (by robe):
* component: topology => QA/buildbots
* resolution: fixed =>
* status: closed => reopened
Comment:
Okay 17 is still failing but might be something fishy with 17 setup. I'm
retesting with 16 and lower. Given 18 is passing, I'm going to assume
this is not a topology specific issue and something to do with with
winnie's PG17 build. Why anything would cause just one test to fail and
not fail on the other PGs is strange.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5956#comment:5>
