[PostGIS] #5953: Slow st_intersection with big input polygons
trac at osgeo.org
Thu Jul 31 00:47:35 PDT 2025
Reporter: Lars Aksel Opsahl | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 3.6.0
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by Lars Aksel Opsahl):
Thanks for your feedback
Replying to [comment:2 mdavis]:
> My take on this is:
> As for the slower no-holes polygon intersection query, this is indeed an
apparent anomaly, since a simpler polygon with fewer vertices should
provide faster intersection. However, the no-holes polygon query isn't an
equivalent comparison, since it runs `ST_BuildArea` and `ST_Boundary`.
These might be taking significant time. Materializing the boundary
polygon in a separate table would reveal if this is the cause of the
slowdown.
Good point I am running that test now.
To create the new input test table is fast as you see.
CREATE table klima.plantegning_3035_test_no_hole AS
select ST_BuildArea(ST_Boundary(geo)) as geo from
klima.plantegning_3035_test;
SELECT 1
Time: 170,497 ms
The new table
\d klima.plantegning_3035_test_no_hole
Table
"klima.plantegning_3035_test_no_hole"
Column | Type | Collation | Nullable |
Default
geo | geometry | | |
id | integer | | not null |
nextval('klima.plantegning_3035_test_no_hole_id_seq'::regclass)
Indexes:
"plantegning_3035_test_no_hole_pkey" PRIMARY KEY, btree (id)
"plantegning_3035_test_no_hole_geo_idx" gist (geo)
I am now running the command below against the new table
explain analyze select sum(ST_area(st_intersection(gk.geom, pt.geo)))
FROM
klima.plantegning_3035_test_no_hole pt,
klima.gk_02 AS gk
WHERE ST_Intersects(gk.geom, pt.geo)
Will report back when this is done.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5953#comment:3>
