[SCM] PostGIS branch master updated. 3.5.0-353-g65789d316
Mon Jun 2 09:50:10 PDT 2025
the project "PostGIS".
       via  65789d316df326e332d4fd22032a885081766f8e (commit)
      from  7829205c550b4235fdfe9b44775e72b121b34aa8 (commit)
revisions in full, below.
commit 65789d316df326e332d4fd22032a885081766f8e
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Jun 2 09:48:46 2025 -0700
    Add ST_CoverageClean, window function to repair overlaps and
    gaps in polygonal coverages. Available with GEOS 3.14 and
    greater.
diff --git a/NEWS b/NEWS
index dcc53e03d..a827c8da9 100644
--- a/NEWS
+++ b/NEWS
@@ -28,4 +28,6 @@ To take advantage of all SFCGAL features, SFCGAL 2.1+ is needed.
            Straight Skeleton Partition) from SFCGAL 2 (Loïc Bartoletti)
   - [raster] New GUC postgis.gdal_cpl_debug, enables GDAL debugging messages
     and routes them into the PostgreSQL logging system. (Paul Ramsey)
-  - #5841, Change interrupt handling to remove use of pqsignal to support PG 18 (Paul Ramsey)
\ No newline at end of file
+  - #5841, Change interrupt handling to remove use of pqsignal to support PG 18 (Paul Ramsey)
+  - Add ST_CoverageClean to edge match and gap remove polygonal
+    coverages (Paul Ramsey) from GEOS 3.14 (Martin Davis)
diff --git a/doc/reference_coverage.xml b/doc/reference_coverage.xml
index d315c6e50..cab673ff1 100644
--- a/doc/reference_coverage.xml
+++ b/doc/reference_coverage.xml
@@ -109,6 +109,7 @@ SELECT true = ALL (
       <para>
         <xref linkend="ST_IsValid"/>,
         <xref linkend="ST_CoverageUnion"/>,
+        <xref linkend="ST_CoverageClean"/>,
         <xref linkend="ST_CoverageSimplify"/>
       </para>
     </refsection>
@@ -212,7 +213,9 @@ SELECT id, ST_AsText(ST_CoverageSimplify(geom, 30) OVER ())
     <refsection>
       <title>See Also</title>
       <para>
-        <xref linkend="ST_CoverageInvalidEdges"/>
+        <xref linkend="ST_CoverageInvalidEdges"/>,
+        <xref linkend="ST_CoverageUnion"/>,
       </para>
     </refsection>
@@ -301,9 +304,90 @@ MULTIPOLYGON (((10 150, 80 190, 110 150, 140 80, 120 10, 10 10, 10 150), (50 60,
       <para>
+        <xref linkend="ST_CoverageSimplify"/>,
         <xref linkend="ST_Union"/>
       </para>
     </refsection>
   </refentry>
+  <refentry xml:id="ST_CoverageClean">
+    <refnamediv>
+      <refname>ST_CoverageClean</refname>
+      <refpurpose>Computes a clean (edge matched, non-overlapping, gap-cleared) polygonal coverage, given a non-clean input.</refpurpose>
+    </refnamediv>
+    <refsynopsisdiv>
+      <funcsynopsis>
+        <funcprototype>
+          <funcdef>geometry <function>ST_CoverageClean</function></funcdef>
+          <paramdef><type>geometry winset</type>
+            <parameter>geom</parameter></paramdef>
+          <paramdef choice="opt"><type>float8 </type>
+            <parameter>snappingDistance = -1</parameter></paramdef>
+            <parameter>gapMaximumWidth = 0</parameter></paramdef>
+          <paramdef choice="opt"><type>text </type>
+            <parameter>overlapMergeStrategy = 'MERGE_LONGEST_BORDER'</parameter></paramdef>
+        </funcprototype>
+      </funcsynopsis>
+    </refsynopsisdiv>
+    <refsection>
+      <title>Description</title>
+      <para>A window function which alters the edges of a polygonal coverage to ensure that none of the polygons overlap, that small gaps are snapped away, and that all shared edges are exactly identical. The result is a clean coverage that will pass validation tests like <xref linkend="ST_CoverageInvalidEdges"/></para>
+      <para>The <parameter>snappingDistance</parameter> controls the node snapping step, when nearby vertices are snapped together. The default setting (-1) applies an automatic snapping distance based on an analysis of the input. Set to 0.0 to turn off all snapping.</para>
+      <para>The <parameter>gapMaximumWidth</parameter> controls the cleaning of gaps between polygons. Gaps smaller than this tolerance will be closed.</para>
+      <para>The <parameter>overlapMergeStrategy</parameter> controls the algorithm used to determine which neighboring polygons to merge overlapping areas into.</para>
+      <para><code>MERGE_LONGEST_BORDER</code> chooses polygon with longest common border</para>
+      <para><code>MERGE_MAX_AREA</code> chooses polygon with maximum area</para>
+      <para><code>MERGE_MIN_AREA</code> chooses polygon with minimum area</para>
+      <para><code>MERGE_MIN_INDEX</code> chooses polygon with smallest input index</para>
+      <para role="availability" conformance="3.6.0">Availability: 3.6.0 - requires GEOS >= 3.14.0</para>
+    </refsection>
+    <refsection>
+      <title>Examples</title>
+      <programlisting>-- Populate demo table
+CREATE TABLE example AS SELECT * FROM (VALUES
+  (1, 'POLYGON ((10 190, 30 160, 40 110, 100 70, 120 10, 10 10, 10 190))'::geometry),
+  (2, 'POLYGON ((100 190, 10 190, 30 160, 40 110, 50 80, 74 110.5, 100 130, 140 120, 140 160, 100 190))'::geometry),
+  (3, 'POLYGON ((140 190, 190 190, 190 80, 140 80, 140 190))'::geometry),
+  (4, 'POLYGON ((180 40, 120 10, 100 70, 140 80, 190 80, 180 40))'::geometry)
+) AS v(id, geom);
+-- Prove it is a dirty coverage
+SELECT ST_AsText(ST_CoverageInvalidEdges(geom) OVER ())
+  FROM example;
+-- Clean the coverage
+CREATE TABLE example_clean AS
+  SELECT id, ST_CoverageClean(geom) OVER () AS GEOM
+  FROM example;
+-- Prove it is a clean coverage
+  FROM example_clean;
+      </programlisting>
+    </refsection>
+    <refsection>
+      <title>See Also</title>
+      <para>
+        <xref linkend="ST_Union"/>
+      </para>
+    </refsection>
+  </refentry>
 </section>
diff --git a/postgis/lwgeom_window.c b/postgis/lwgeom_window.c
index 715eecbbb..d4007a537 100644
--- a/postgis/lwgeom_window.c
+++ b/postgis/lwgeom_window.c
@@ -29,6 +29,7 @@
 #include "postgres.h"
 #include "funcapi.h"
 #include "windowapi.h"
+#include "utils/builtins.h"
 /* PostGIS */
 #include "liblwgeom.h"
@@ -543,7 +544,8 @@ coverage_read_partition_into_collection(
 		 * GEOS nulls or empties. So we need to maintain a
 		 * map (context->idx) from the window position of the
 		 * input to the GEOS position, so we can put the
-		 * right result in the output stream.
+		 * right result in the output stream. Things we want to
+		 * skip get an index of -1.
 		/* Skip NULL inputs and move on */
@@ -581,7 +583,7 @@ coverage_read_partition_into_collection(
 	 * Create the GEOS input collection! The new
 	 * collection takes ownership of the input GEOSGeometry
-	 * objects, leaving just the ngeoms array, which
+	 * objects, leaving just the geoms array, which
 	 * will be cleaned up on function exit.
 	geos = GEOSGeom_createCollection(
@@ -612,10 +614,38 @@ coverage_read_partition_into_collection(
  * operating mode is controlled with this enumeration.
 enum {
-	COVERAGE_SIMPLIFY = 0,
-	COVERAGE_ISVALID = 1
+	 COVERAGE_SIMPLIFY = 0
+	,COVERAGE_ISVALID  = 1
+#if POSTGIS_GEOS_VERSION >= 31400
+	,COVERAGE_CLEAN    = 2
+#endif
+static char * overlapMergeStrategies[] = {
+    /* Merge strategy that chooses polygon with longest common border */
+    "MERGE_LONGEST_BORDER",
+    /* Merge strategy that chooses polygon with maximum area */
+    "MERGE_MAX_AREA",
+    /* Merge strategy that chooses polygon with minimum area */
+    "MERGE_MIN_AREA",
+    /* Merge strategy that chooses polygon with smallest input index */
+    "MERGE_MIN_INDEX"
+static int
+coverage_merge_strategy(const char *strategy)
+	size_t stratLen = sizeof(overlapMergeStrategies) / sizeof(overlapMergeStrategies[0]);
+	for (size_t i = 0; i < stratLen; i++)
+		if (strcasecmp(strategy, overlapMergeStrategies[i]) == 0)
+			return i;
+	return -1;
  * This calculation is shared by both coverage operations
  * since they have the same pattern of "consume collection,
@@ -636,11 +666,9 @@ coverage_window_calculation(PG_FUNCTION_ARGS, int mode)
 	if (!context->isdone)
 		bool isnull;
-		Datum d;
-		double tolerance = 0.0;
-		bool simplifyBoundary = true;
 		GEOSGeometry *output = NULL;
 		GEOSGeometry *input = NULL;
+		Datum d;
 		if (!fcinfo->flinfo)
 			elog(ERROR, "%s: Could not find upper context", __func__);
@@ -652,20 +680,6 @@ coverage_window_calculation(PG_FUNCTION_ARGS, int mode)
 			PG_RETURN_NULL();
-		/* Get the tolerance argument from second position */
-		d = WinGetFuncArgCurrent(winobj, 1, &isnull);
-		if (!isnull)
-			tolerance = DatumGetFloat8(d);
-		/* The third position "preserve boundary" argument */
-		/* is only for the simplify mode */
-		if (mode == COVERAGE_SIMPLIFY)
-			d = WinGetFuncArgCurrent(winobj, 2, &isnull);
-			if (!isnull)
-				simplifyBoundary = DatumGetBool(d);
 		initGEOS(lwpgnotice, lwgeom_geos_error);
 		input = coverage_read_partition_into_collection(winobj, context);
@@ -675,13 +689,71 @@ coverage_window_calculation(PG_FUNCTION_ARGS, int mode)
 		/* Run the correct GEOS function for the calling mode */
+			bool simplifyBoundary = true;
+			double tolerance = 0.0;
+			d = WinGetFuncArgCurrent(winobj, 1, &isnull);
+			if (!isnull) tolerance = DatumGetFloat8(d);
+			d = WinGetFuncArgCurrent(winobj, 2, &isnull);
+			if (!isnull) simplifyBoundary = DatumGetFloat8(d);
 			/* GEOSCoverageSimplifyVW is "preserveBoundary" so we invert simplifyBoundary */
 			output = GEOSCoverageSimplifyVW(input, tolerance, !simplifyBoundary);
 		else if (mode == COVERAGE_ISVALID)
 			GEOSCoverageIsValid(input, tolerance, &output);
+		else if (mode == COVERAGE_CLEAN)
+			double snappingDistance = 0.0;
+			double gapMaximumWidth = 0.0;
+			text *overlapMergeStrategyText;
+			int overlapMergeStrategy;
+			GEOSCoverageCleanParams *params = NULL;
+			if (!isnull) snappingDistance = DatumGetFloat8(d);
+			if (!isnull) gapMaximumWidth = DatumGetFloat8(d);
+			d = WinGetFuncArgCurrent(winobj, 3, &isnull);
+			// if (!isnull) overlapMergeStrategy = DatumGetInt32(d);
+			if (!isnull)
+				overlapMergeStrategyText = DatumGetTextP(d);
+				overlapMergeStrategy = coverage_merge_strategy(text_to_cstring(overlapMergeStrategyText));
+			else
+				overlapMergeStrategy = 0; /* Default to MERGE_LONGEST_BORDER */
+			if (overlapMergeStrategy < 0)
+				HANDLE_GEOS_ERROR("Invalid OverlapMergeStrategy");
+			params = GEOSCoverageCleanParams_create();
+			GEOSCoverageCleanParams_setGapMaximumWidth(params, gapMaximumWidth);
+			GEOSCoverageCleanParams_setSnappingDistance(params, snappingDistance);
+			if (!GEOSCoverageCleanParams_setOverlapMergeStrategy(params, overlapMergeStrategy))
+				GEOSCoverageCleanParams_destroy(params);
+			output = GEOSCoverageCleanWithParams(input, params);
+#endif
 		else
 			elog(ERROR, "Unknown mode, never get here");
@@ -752,8 +824,8 @@ Datum ST_CoverageSimplify(PG_FUNCTION_ARGS)
 #if POSTGIS_GEOS_VERSION < 31200
 	lwpgerror("The GEOS version this PostGIS binary "
-		"was compiled against (%d) doesn't support "
-		"'GEOSCoverageSimplifyVW' function (3.12.0+ required)",
+		"was compiled against (%d) not include "
+		"'GEOSCoverageSimplifyVW' function (3.12 or greater required)",
 		POSTGIS_GEOS_VERSION);
 	PG_RETURN_NULL();
@@ -772,8 +844,8 @@ Datum ST_CoverageInvalidEdges(PG_FUNCTION_ARGS)
-		"'GEOSCoverageIsValid' function (3.12.0+ required)",
+		"was compiled against (%d) does not include "
+		"'GEOSCoverageIsValid' function (3.12 or greater required)",
 	PG_RETURN_NULL();
@@ -784,6 +856,25 @@ Datum ST_CoverageInvalidEdges(PG_FUNCTION_ARGS)
 #endif
+extern Datum ST_CoverageClean(PG_FUNCTION_ARGS);
+PG_FUNCTION_INFO_V1(ST_CoverageClean);
+Datum ST_CoverageClean(PG_FUNCTION_ARGS)
+#if POSTGIS_GEOS_VERSION < 31400
+	lwpgerror("The GEOS version this PostGIS binary "
+		"'GEOSCoverageClean' function (3.14 or greater required)",
+		POSTGIS_GEOS_VERSION);
+	PG_RETURN_NULL();
+#else /* POSTGIS_GEOS_VERSION >= 31400 */
+	return coverage_window_calculation(fcinfo, COVERAGE_CLEAN);
+#endif
  * ST_CoverageUnion(geometry[])
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index ed39bbb0b..64dcf343e 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -4467,6 +4467,13 @@ CREATE OR REPLACE FUNCTION ST_CoverageInvalidEdges (geom geometry, tolerance flo
 	LANGUAGE 'c' IMMUTABLE STRICT WINDOW PARALLEL SAFE
 	_COST_HIGH;
+-- Availability: 3.6.0
+CREATE OR REPLACE FUNCTION ST_CoverageClean (geom geometry, snappingDistance float8 default -1.0, gapMaximumWidth float8 default 0.0, overlapMergeStrategy text default 'MERGE_LONGEST_BORDER')
+	RETURNS geometry
+	AS 'MODULE_PATHNAME', 'ST_CoverageClean'
+	LANGUAGE 'c' IMMUTABLE STRICT WINDOW PARALLEL SAFE
+	_COST_HIGH;
 -- Availability: 2.3.0
Summary of changes:
 NEWS                       |   4 +-
 doc/reference_coverage.xml |  86 ++++++++++++++++++++++++++-
 postgis/lwgeom_window.c    | 141 +++++++++++++++++++++++++++++++++++++--------
 postgis/postgis.sql.in     |   7 +++
 4 files changed, 211 insertions(+), 27 deletions(-)
hooks/post-receive
