[SCM] PostGIS branch master updated. 3.5.0-373-gef795d36e
Thu Jun 5 12:44:56 PDT 2025
the project "PostGIS".
       via  ef795d36e59dad991e0af66802f973fd6bb324b1 (commit)
      from  b9f1c4c6876b7d6bbeb457edf4feac11be48c920 (commit)
revisions in full, below.
commit ef795d36e59dad991e0af66802f973fd6bb324b1
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Jun 5 12:44:51 2025 -0700
    Remove crash when using xlink without a gml prefix, references #5912
diff --git a/postgis/lwgeom_in_gml.c b/postgis/lwgeom_in_gml.c
index 9ccab030b..ae0b96411 100644
--- a/postgis/lwgeom_in_gml.c
+++ b/postgis/lwgeom_in_gml.c
@@ -258,16 +258,29 @@ static xmlNodePtr get_xlink_node(xmlNodePtr xnode)
 	xmlChar *href, *p, *node_id;
 	href = xmlGetNsProp(xnode, (xmlChar *)"href", (xmlChar *) XLINK_NS);
-	id = lwalloc((xmlStrlen(xnode->ns->prefix) * 2 + xmlStrlen(xnode->name)
-	              + xmlStrlen(href) + sizeof("//:[@:id='']") + 1));
 	p = href;
 	p++; /* ignore '#' first char */
-	/* XPath pattern look like: //gml:point[@gml:id='p1'] */
-	sprintf(id, "//%s:%s[@%s:id='%s']", 	(char *) xnode->ns->prefix,
-	        (char *) xnode->name,
-	        (char *) xnode->ns->prefix,
-	        (char *) p);
+	if (xnode->ns)
+		id = lwalloc((xmlStrlen(xnode->ns->prefix) * 2 + xmlStrlen(xnode->name) +
+		/* XPath pattern look like: //gml:point[@gml:id='p1'] */
+		sprintf(id, "//%s:%s[@%s:id='%s']",
+		        (char *) xnode->ns->prefix,
+		        (char *) xnode->name,
+		        (char *) p);
+	else
+		id = lwalloc((xmlStrlen(xnode->name) +
+		sprintf(id, "//%s[@id='%s']",
+		        (char *) p);
 	ctx = xmlXPathNewContext(xnode->doc);
 	if (ctx == NULL)
@@ -1004,6 +1017,8 @@ static LWGEOM* parse_gml_point(xmlNodePtr xnode, bool *hasz, int *root_srid)
 	POINTARRAY *pa;
 	if (is_xlink(xnode)) xnode = get_xlink_node(xnode);
+	if (xnode == NULL)
+		gml_lwpgerror("invalid GML representation", 30);
 	if (xnode->children == NULL)
 		return lwpoint_as_lwgeom(lwpoint_construct_empty(*root_srid, 0, 0));
@@ -1039,6 +1054,8 @@ static LWGEOM* parse_gml_line(xmlNodePtr xnode, bool *hasz, int *root_srid)
 	POINTARRAY *pa;
 		return lwline_as_lwgeom(lwline_construct_empty(*root_srid, 0, 0));
@@ -1080,6 +1097,8 @@ static LWGEOM* parse_gml_curve(xmlNodePtr xnode, bool *hasz, int *root_srid)
 	xmlChar *interpolation=NULL;
 	/* Looking for gml:segments */
 	for (xa = xnode->children ; xa != NULL ; xa = xa->next)
@@ -1186,6 +1205,8 @@ static LWGEOM* parse_gml_linearring(xmlNodePtr xnode, bool *hasz, int *root_srid
 	POINTARRAY **ppa = NULL;
 	parse_gml_srs(xnode, &srs);
 	ppa = (POINTARRAY**) lwalloc(sizeof(POINTARRAY*));
@@ -1220,6 +1241,8 @@ static LWGEOM* parse_gml_polygon(xmlNodePtr xnode, bool *hasz, int *root_srid)
 		return lwpoly_as_lwgeom(lwpoly_construct_empty(*root_srid, 0, 0));
@@ -1314,6 +1337,8 @@ static LWGEOM* parse_gml_triangle(xmlNodePtr xnode, bool *hasz, int *root_srid)
 		return lwtriangle_as_lwgeom(lwtriangle_construct_empty(*root_srid, 0, 0));
@@ -1480,6 +1505,8 @@ static LWGEOM* parse_gml_surface(xmlNodePtr xnode, bool *hasz, int *root_srid)
 	bool found=false;
 	/* Looking for gml:patches */
@@ -1532,6 +1559,8 @@ static LWGEOM* parse_gml_tin(xmlNodePtr xnode, bool *hasz, int *root_srid)
 	bool found=false;
 	if (*root_srid == SRID_UNKNOWN && srs.srid != SRID_UNKNOWN)
@@ -1582,6 +1611,8 @@ static LWGEOM* parse_gml_mpoint(xmlNodePtr xnode, bool *hasz, int *root_srid)
 	LWGEOM *geom = NULL;
@@ -1628,6 +1659,8 @@ static LWGEOM* parse_gml_mline(xmlNodePtr xnode, bool *hasz, int *root_srid)
@@ -1663,6 +1696,8 @@ static LWGEOM* parse_gml_mcurve(xmlNodePtr xnode, bool *hasz, int *root_srid)
@@ -1710,6 +1745,8 @@ static LWGEOM* parse_gml_mpoly(xmlNodePtr xnode, bool *hasz, int *root_srid)
@@ -1745,6 +1782,8 @@ static LWGEOM* parse_gml_msurface(xmlNodePtr xnode, bool *hasz, int *root_srid)
@@ -1793,6 +1832,8 @@ static LWGEOM* parse_gml_psurface(xmlNodePtr xnode, bool *hasz, int *root_srid)
@@ -1841,6 +1882,8 @@ static LWGEOM* parse_gml_coll(xmlNodePtr xnode, bool *hasz, int *root_srid)
diff --git a/regress/core/in_gml.sql b/regress/core/in_gml.sql
index cfdb1b5a3..d676ef688 100644
--- a/regress/core/in_gml.sql
+++ b/regress/core/in_gml.sql
@@ -996,6 +996,9 @@ SELECT 'xlink_22', ST_AsEWKT(ST_GeomFromGML('<gml:MultiGeometry xmlns:gml="http:
 -- ERROR circular ref
 SELECT 'xlink_23', ST_AsEWKT(ST_GeomFromGML('<gml:MultiGeometry gml:id="mg1" xmlns:gml="http://www.opengis.net/gml" xmlns:xlink="http://www.w3.org/1999/xlink"><gml:geometryMember><gml:Point><gml:pos>1 2</gml:pos></gml:Point></gml:geometryMember><gml:geometryMember><gml:MultiGeometry xlink:type="simple" xlink:href="#mg1"/></gml:geometryMember></gml:MultiGeometry>'));
+-- XLink no gml namespace
+SELECT 'xlink_1_no_ns', ST_AsEWKT(ST_GeomFromGML('<LineString xmlns:xlink="http://www.w3.org/1999/xlink"><pointProperty><Point id="p1"><pos>1 2</pos></Point></pointProperty><pointProperty><Point xlink:type="simple" xlink:href="#p1"/></pointProperty><pos>3 4</pos></LineString>'));
 -- Bijective PostGIS GML test
diff --git a/regress/core/in_gml_expected b/regress/core/in_gml_expected
index 556f58ce3..1bd48ba70 100644
--- a/regress/core/in_gml_expected
+++ b/regress/core/in_gml_expected
@@ -332,6 +332,7 @@ xlink_20|GEOMETRYCOLLECTION(MULTIPOLYGON(((1 2,3 4,5 6,1 2))),MULTIPOLYGON(((1 2
 xlink_21|GEOMETRYCOLLECTION(MULTIPOLYGON(((1 2,3 4,5 6,1 2))),MULTIPOLYGON(((1 2,3 4,5 6,1 2))))
 xlink_22|GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(POINT(1 2)),GEOMETRYCOLLECTION(POINT(1 2)))
 ERROR:  invalid GML representation
+xlink_1_no_ns|LINESTRING(1 2,1 2,3 4)
 gml_1|POINT(1 2)
 gml_2|POINT(1 2 3)
 gml_3|SRID=27582;POINT(1 2)
Summary of changes:
 postgis/lwgeom_in_gml.c      | 57 ++++++++++++++++++++++++++++++++++++++------
 regress/core/in_gml.sql      |  3 +++
 regress/core/in_gml_expected |  1 +
 3 files changed, 54 insertions(+), 7 deletions(-)
hooks/post-receive
