[SCM] PostGIS branch master updated. 3.5.0-400-g7fafa07fc
git at osgeo.org
git at osgeo.org
Sat Jun 14 02:21:50 PDT 2025
the project "PostGIS".
via 7fafa07fc293ec2a6326b8586fc0f747514ed9b2 (commit)
from a7da2ce57d27b54c3075755d969d21eabb31c871 (commit)
revisions in full, below.
commit 7fafa07fc293ec2a6326b8586fc0f747514ed9b2
Author: Regina Obe <lr at pcorp.us>
Date: Sat Jun 14 05:21:30 2025 -0400
Schema qualify geometry CAST in ST_GeomFromHash so can be used in materialized views
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 998ae2a73..51fba0988 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -5400,7 +5400,7 @@ CREATE OR REPLACE FUNCTION ST_PointFromGeoHash(text, integer DEFAULT NULL)
-- ST_GeomFromGeoHash(geohash text, precision integer)
CREATE OR REPLACE FUNCTION ST_GeomFromGeoHash(text, integer DEFAULT NULL)
RETURNS geometry
- AS $$ SELECT CAST(@extschema at .ST_Box2dFromGeoHash($1, $2) AS geometry); $$
+ AS $$ SELECT CAST(@extschema at .ST_Box2dFromGeoHash($1, $2) AS @extschema at .geometry); $$
LANGUAGE 'sql' IMMUTABLE PARALLEL SAFE
_COST_LOW;
Summary of changes:
postgis/postgis.sql.in | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
