[PostGIS] #5928: ST_Collect creates invalid result with only valid input
trac at osgeo.org
Tue Jun 24 07:50:08 PDT 2025
Reporter: Lars Aksel Opsahl | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.0
Component: postgis | Version: 3.5.x
Resolution: | Keywords:
Comment (by pramsey):
Your simple example doesn't occur for me.
select ST_IsValid('GEOMETRYCOLLECTION(POLYGON((0 0,10 0,5 5,0
0)),POLYGON((5 4,10 0,15 5,5 4)))');
st_isvalid
t
-- POSTGIS="3.6.0dev 3.5.0-404-g4e4b425e2" [EXTENSION] PGSQL="180"
GEOS="3.14.0dev-CAPI-1.20.0" PROJ="9.6.2 NETWORK_ENABLED=ON
URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/Users/pramsey/Library/Application Support/proj
DATABASE_PATH=/opt/homebrew/Cellar/proj/9.6.2/share/proj/proj.db"
(compiled against PROJ 9.6.2) LIBXML="2.9.13" LIBJSON="0.18"
LIBPROTOBUF="1.5.2" WAGYU="0.5.0 (Internal)"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5928#comment:3>
