[PostGIS] #5929: Spatial exception Postgis Topology missing info
trac at osgeo.org
Fri Jun 27 05:01:44 PDT 2025
Reporter: Lars Aksel Opsahl | Owner: strk
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 3.5.4
Component: topology | Version: 3.5.x
Resolution: wontfix | Keywords:
Changes (by Lars Aksel Opsahl):
* resolution: => wontfix
* status: new => closed
Comment:
It seems to quite hard to create a small failing context.
I have now tried with this cmd's to geom involved and even then I am not
able to cases that does produces a failing tests for all cases.
Format('SELECT distinct geom, edge_id FROM %1$s.edge_data WHERE
abs(next_left_edge) = %2$s or edge_id = %2$s or abs(next_right_edge) =
%2$s order by abs(edge_id);',
_topology_name, error_edge_id);
ST_intersects(%2$L,geom);',_topology_name,new_line);
This basicly means in some case we need the whole topology to create an
error context.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5929#comment:1>
