[SCM] PostGIS branch master updated. 3.5.0-407-g5e68c1b71
Fri Jun 27 14:19:54 PDT 2025
the project "PostGIS".
       via  5e68c1b711f5c1c9a61443970680375f33bf85cb (commit)
       via  b60b71d6883140b499b41ee23b58fd841ea27fcc (commit)
      from  2a4047bb383d2d94e3b4ab45a71dbe2a332d9ebe (commit)
revisions in full, below.
commit 5e68c1b711f5c1c9a61443970680375f33bf85cb
Merge: 2a4047bb3 b60b71d68
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Jun 27 14:19:50 2025 -0700
    Merge branch 'ibat-alliance-master'
commit b60b71d6883140b499b41ee23b58fd841ea27fcc
Author: Nikolai <nikolai-b at users.noreply.github.com>
Date:   Mon Jun 23 15:33:06 2025 +0100
    Improve St_Buffer doc note
    Prefer ST_MakeValid over ST_Buffer
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index 93f6abbd0..8144058a4 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -98,10 +98,9 @@ This is only applicable to LINESTRING geometry and does not affect POINT or POLY
             This may not produce the desired behavior if the input object is much larger than a UTM zone or crosses the dateline
             </para></note>
-            <note><para>Buffer output is always a valid polygonal geometry.
-            Buffer can handle invalid inputs,
-            so buffering by distance 0 is sometimes used as a way of repairing invalid polygons.
-            <xref linkend="ST_MakeValid"/> can also be used for this purpose.
+            <note><para>Buffer can handle invalid inputs and the output is always a valid polygonal geometry.
+            Buffering by distance 0 is sometimes used as a way of repairing invalid polygons.
+            <xref linkend="ST_MakeValid"/> is more suitable for this process as it can handle multi-polygons.
             </para></note>
             <note><para>Buffering is sometimes used to perform a within-distance search.
Summary of changes:
 doc/reference_processing.xml | 7 +++----
 1 file changed, 3 insertions(+), 4 deletions(-)
hooks/post-receive
