[PostGIS] #5857: compile against PostgreSQL 18 failing gserialized_estimate.c:1508:17: error: too few arguments to function 'vacuum_delay_point'
PostGIS trac at osgeo.org
Sun Mar 2 18:45:06 PST 2025
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.5.3
 Component:  postgis  |    Version:  3.4.x
Resolution:           |   Keywords:
Description changed by robe:
Old description:
> I just tried building against PostgreSQL 18 master head
> and got this error:
> geography_measurement_trees.o geography_measurement_trees.c
> gserialized_estimate.c: In function 'compute_gserialized_stats_mode':
>  1508 |                 vacuum_delay_point();
> In file included from gserialized_estimate.c:97:
> C:/ming64/projects/POSTGR~1/rel/pg18w64/include/server/commands/vacuum.h:362:13:
> note: declared here
>   362 | extern void vacuum_delay_point(bool is_analyze);
> gserialized_estimate.c:1726:17: error: too few arguments to function
>  1726 |                 vacuum_delay_point();
> note: declared here
> make[1]: *** [<builtin>: gserialized_estimate.o] Error 1
> make[1]: *** Waiting for unfinished jobs....
> make[1]: Leaving directory '/projects/postgis/postgis-git/postgis'
> make: *** [GNUmakefile:36: all] Error 1
New description:
 and got this error:
 note: declared here
 note: declared here
 Failure is caused by this PostgreSQL commit 3 weeks ago. Unfortunately
 debbie's git was having issue so the pg18 build-env builds were failing so
 didn't catch this:
 https://git.postgresql.org/gitweb/?p=postgresql.git;a=commit;h=e5b0b0c
 Add is_analyze parameter to vacuum_delay_point().
 This function is used in both vacuum and analyze code paths, and a
 follow-up commit will require distinguishing between the two.  This
 commit forces callers to specify whether they are in a vacuum or
 analyze path, but it does not use that information for anything
 yet.
 Discussion: https://postgr.es/m/ZmaXmWDL829fzAVX%40ip-10-97-1-34.eu-
 west-3.compute.internal
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5857#comment:2>
