[PostGIS] #5862: Postgis topology, silently craating topo edge crosses edge , mixed face labeling in ring
trac at osgeo.org
Wed Mar 12 08:32:08 PDT 2025
labeling in ring
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: high | Milestone:
Component: topology | Version: master
Resolution: | Keywords:
Changes (by strk):
* priority: medium => high
Comment:
Confirmed with
> POSTGIS="3.6.0dev 3.5.0-221-g450d3b770" [EXTENSION] PGSQL="170"
GEOS="3.14.0dev-CAPI-1.20.0" PROJ="9.1.1 NETWORK_ENABLED=OFF
URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/tmp/proj
DATABASE_PATH=/usr/share/proj/proj.db" (compiled against PROJ 9.1.1)
LIBXML="2.9.14" LIBJSON="0.16" LIBPROTOBUF="1.4.1" WAGYU="0.5.0
(Internal)" (core procs from "3.6.0dev 3.5.0-61-gf8c391052" need upgrade)
TOPOLOGY (topology procs from "3.6.0dev 3.5.0-61-gf8c391052" need upgrade)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5862#comment:1>
