[PostGIS] #5859: Postgis Topology err Programmatic error ? Geometry of face 1098 is empty!
PostGIS trac at osgeo.org
Wed Mar 12 09:43:48 PDT 2025
  Reporter:  Lars Aksel Opsahl  |      Owner:  strk
      Type:  defect             |     Status:  new
  Priority:  medium             |  Milestone:  PostGIS 3.6.0
 Component:  topology           |    Version:  master
Resolution:                     |   Keywords:  robustness
Comment (by strk):
 The problem is that no matter tolerance you would still NOT snap an
 incoming vertex to a pre-existing segment. At the moment we always ever
 snap incoming SEGMENTS to pre-existing VERTEXES. Except when a new
 intersection point is detected (as it is likely the case with #5862)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5859#comment:8>
