[PostGIS] #5870: liblwgeom compile failure on PG17 and PG18 GHA runs
trac at osgeo.org
Sat Mar 22 15:17:02 PDT 2025
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS SFCGAL
Component: postgis | Version: master
Resolution: | Keywords:
Changes (by robe):
* milestone: PostGIS 3.6.0 => PostGIS SFCGAL
Comment:
Okay this appears to be probably because of upgrade in sfcgal and so makes
sense only the cis following sfcgal master failed.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5870#comment:3>
