[PostGIS] #5871: GHA latest run failing on GDAL
PostGIS trac at osgeo.org
Sun Mar 23 18:54:01 PDT 2025
 Reporter:  robe    |      Owner:  robe
     Type:  defect  |     Status:  new
 Priority:  medium  |  Milestone:  PostGIS 3.6.0
Component:  raster  |    Version:  master
 Keywords:          |
 I'm assuming something changed in GDAL (or PG18), most likely GDAL because
 PG17 geos-main/gdal 3.9 run is fine, but latest which tests against PG18
 and GDAL head is erroring with:
  raster/test/regress/loader/Projected .... failed ( test: running
 raster2pgsql output: /tmp/pgis_reg/loader.err)
 BEGIN
 CREATE TABLE
 CREATE TABLE
 psql:/tmp/pgis_reg/loader.out:4: ERROR:  rt_raster_from_gdal_dataset:
 Could not get data from GDAL raster
 CONTEXT:  SQL function "st_transform" statement 1
  failed (Errors while running sql script ./raster/test/regress/loader
 /Projected-post.sql: /tmp/pgis_reg/test_332_tmp)
 ERROR:  table "o_2_loadedrast" does not exist
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5871>
