[PostGIS] #5893: regress/core/geos39 failing on geos 3.14.0dev
trac at osgeo.org
Fri May 2 19:30:54 PDT 2025
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS GEOS
Component: postgis | Version: 3.4.x
Keywords: |
+++ /projects/postgis/tmp/3.6.0dev_pg17_geos3.14_gdal3.9.2w64/test_119_out
2025-05-02 22:03:29.465152000 -0400
@@ -1,10 +1,10 @@
-mic-box|POINT(49.5117 49.5117)|POINT(50.5111 98.9796)|49.4779
+mic-box|POINT(49.495 49.495)|POINT(50.4947 98.9799)|49.4950
mic-empty|POINT EMPTY|POINT EMPTY|0.0000
mic-null|||
mic-line|POINT(49.5117 49.5117)|POINT(50.5111 98.9796)|49.4779
mic-mpoint|POINT(48.584 49.9512)|POINT(99 98)|69.6453
mic-point|POINT(0 0)|POINT(0 0)|0.0000
-mic-cte|POINT(49.512 49.512)
+mic-cte|POINT(49.495 49.495)
rp-1|POINT(1.4 19.3)
rp-2|POINT(1 19)
rp-3|POINT(0 20)
Grrh seeing this failure on winnie and debbie testing geos-main
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5893>
