[PostGIS] #5893: regress/core/geos39 failing on geos 3.14.0dev
PostGIS trac at osgeo.org
Sun May 4 12:04:41 PDT 2025
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS GEOS
 Component:  postgis  |    Version:  3.4.x
Resolution:           |   Keywords:
Changes (by robe):
 * owner:  pramsey => robe
Old description:
> /projects/postgis/tmp/3.6.0dev_pg17_geos3.14_gdal3.9.2w64/test_119_out
> 2025-05-02 22:03:29.465152000 -0400
> @@ -1,10 +1,10 @@
> -mic-box|POINT(49.5117 49.5117)|POINT(50.5111 98.9796)|49.4779
> +mic-box|POINT(49.495 49.495)|POINT(50.4947 98.9799)|49.4950
>  mic-empty|POINT EMPTY|POINT EMPTY|0.0000
>  mic-null|||
>  mic-line|POINT(49.5117 49.5117)|POINT(50.5111 98.9796)|49.4779
>  mic-mpoint|POINT(48.584 49.9512)|POINT(99 98)|69.6453
>  mic-point|POINT(0 0)|POINT(0 0)|0.0000
> -mic-cte|POINT(49.512 49.512)
> +mic-cte|POINT(49.495 49.495)
>  rp-1|POINT(1.4 19.3)
>  rp-2|POINT(1 19)
>  rp-3|POINT(0 20)
> Grrh seeing this failure on winnie and debbie testing geos-main
New description:
 +++ /projects/postgis/tmp/3.6.0dev_pg17_geos3.14_gdal3.9.2w64/test_119_out
 @@ -1,10 +1,10 @@
  mic-null|||
  rp-2|POINT(1 19)
  rp-3|POINT(0 20)
Comment:
 As Martin and Paul mentioned in matrix/irc -- GEOS was changed recently
 "MIC has been enhanced to compute exact results for small polygons
 (triangles and quadrilaterals).  So this could change the result value -
 but only to within the tolerance value provided by the user.  Perhaps the
 tests are not using that same tolerance?"
 So sounds like we need to revise the regress.  I'll take a stab at making
 it work for newer and older geos.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5893#comment:1>
