[PostGIS] #5893: regress/core/geos39 failing on geos 3.14.0dev
PostGIS trac at osgeo.org
Mon May 5 08:58:14 PDT 2025
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS GEOS
 Component:  postgis  |    Version:  3.4.x
Resolution:           |   Keywords:
Comment (by pramsey):
 I see the same results directly in GEOS so this is a GEOS issue. Still
 need to confirm if this is GEOS differing from JTS or both libraries just
 having a small output change under the new algorithm.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5893#comment:2>
