[PostGIS] #5893: regress/core/geos39 failing on geos 3.14.0dev
    trac at osgeo.org
    Mon May  5 10:02:39 PDT 2025
  Reporter:  robe     |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS GEOS
 Component:  postgis  |    Version:  3.4.x
Resolution:           |   Keywords:
Comment (by mdavis):
 Replying to [comment:2 pramsey]:
 > Still need to confirm if this is GEOS differing from JTS or both
 libraries just having a small output change under the new algorithm.
 It's an output change in both libs.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5893#comment:3>
