[PostGIS] #5878: debbie jobs failing on bad GDAL
trac at osgeo.org
Mon May 12 14:35:15 PDT 2025
Reporter: robe | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.4.5
Component: QA/buildbots | Version: 3.4.x
Resolution: fixed | Keywords:
Changes (by robe):
* resolution: => fixed
* status: new => closed
Comment:
this is fixed. Just had to make sure I changed all debbie PostGIS
branches to use the same version of GDAL.
The problem with using different GDAL versions in each branch is because
GDAL libs change name, so if an older built postgis from another branch is
built with a different GDAL minor, the new GDAL can't be used to support
the old postgis lib because via the env variables there is only one
version of GDAL in path which is the version specified for the current
running regress branch.
This isn't an issue with GEOS since GEOS lib names don't change from minor
to minor.
I suppose in theory maybe there is a way to force the libname of GDAL to
stay the same but haven't researched to see how that could be done. Other
option is just to copy all the GDAL lib files in same folderand have PG
env variables reference that folder instead of different folders.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5878#comment:1>
