[PostGIS] #5149: ST_AlphaShape crashes with malformed input (garden test crash)
trac at osgeo.org
Tue May 13 01:10:52 PDT 2025
Reporter: robe | Owner: robe
Type: defect | Status: closed
Priority: high | Milestone: PostGIS SFCGAL
Component: sfcgal | Version: master
Resolution: fixed | Keywords: windows
Changes (by Loïc Bartoletti):
* resolution: => fixed
* status: new => closed
Old description:
> POSTGIS="3.3.0dev 3.2.0-792-g78308862c" [EXTENSION] PGSQL="110"
> GEOS="3.11.0dev-CAPI-1.16.0" SFCGAL="SFCGAL 1.4.1, CGAL 5.3, BOOST
> 1.78.0" PROJ="7.2.1" GDAL="GDAL 3.4.2, released 2022/03/08"
> LIBXML="2.9.9" LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.5.0
> (Internal)" RASTER PostgreSQL 11.2 on x86_64-pc-mingw64, compiled by
> gcc.exe (x86_64-posix-seh-rev0, Built by MinGW-W64 project) 8.1.0, 64-bit
> SELECT ST_AlphaShape('POLYGON((1 2,1 2,1 2,1 2))', 20.1, false);
New description:
POSTGIS="3.3.0dev 3.2.0-792-g78308862c" [EXTENSION] PGSQL="110" GEOS="3.11
.0dev-CAPI-1.16.0" SFCGAL="SFCGAL 1.4.1, CGAL 5.3, BOOST 1.78.0"
PROJ="7.2.1" GDAL="GDAL 3.4.2, released 2022/03/08" LIBXML="2.9.9"
LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.5.0 (Internal)" RASTER
PostgreSQL 11.2 on x86_64-pc-mingw64, compiled by gcc.exe (x86_64-posix-
Comment:
Fixed in SFCGAL 2.1.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5149#comment:3>
