[SCM] PostGIS branch master updated. 3.5.0-327-g4dbb16abf
Fri May 16 08:31:32 PDT 2025
the project "PostGIS".
       via  4dbb16abff83a66f9d24dc76324959320e0842c9 (commit)
       via  2c919442784f8db2c38de1f1e837df8e50ed8487 (commit)
      from  8bc70be1682ca740bc6e24260b454ebed0274779 (commit)
revisions in full, below.
commit 4dbb16abff83a66f9d24dc76324959320e0842c9
Merge: 8bc70be16 2c9194427
Author: Regina Obe <lr at pcorp.us>
Date:   Fri May 16 08:31:30 2025 -0700
    Merge pull request 'docs(CG_3DBuffer): fix information about segments and geometries supported' (!249) from lbartoletti/postgis:docs_3Dbuffer into master
    Reviewed-on: https://git.osgeo.org/gitea/postgis/postgis/pulls/249
commit 2c919442784f8db2c38de1f1e837df8e50ed8487
Author: Loïc Bartoletti <loic.bartoletti at oslandia.com>
Date:   Fri May 16 07:33:27 2025 +0200
diff --git a/doc/reference_sfcgal.xml b/doc/reference_sfcgal.xml
index 14006d489..8c9226fda 100644
--- a/doc/reference_sfcgal.xml
+++ b/doc/reference_sfcgal.xml
@@ -3102,16 +3102,14 @@ ERROR:  straight skeleton of Polygon with point touching rings is not implemente
        <title>Description</title>
        <para>Generates a 3D buffer around the input geometry <parameter>geom</parameter> with a specified <parameter>radius</parameter>.
        The buffer is constructed in 3D space, creating a volumetric representation of the geometry's surroundings.
-       The <parameter>segments</parameter> parameter defines the number of segments used to approximate the curved sections of the buffer.
+       The <parameter>segments</parameter> parameter defines the number of segments used to approximate the curved sections of the buffer, with a minimum value of 4 segments required.
        The <parameter>buffer_type</parameter> specifies the type of buffer to create:
        0: Rounded buffer (default)
        1: Flat buffer
        2: Square buffer</para>
+       <para>Input geometry must be a Point or LineString.</para>
        <para role="availability" conformance="3.6.0">Availability: 3.6.0 - requires SFCGAL >= 2.0.0</para>
        <para>&sfcgal_required;</para>
-       <para>&Z_support;</para>
-       <para>&P_support;</para>
-       <para>&T_support;</para>
    </refsection>
    <refsection>
        <title>Examples</title>
Summary of changes:
 doc/reference_sfcgal.xml | 6 ++----
 1 file changed, 2 insertions(+), 4 deletions(-)
hooks/post-receive
