[PostGIS] #5899: pg_upgrade fails restore geography because spatial_ref_sys does not exist
trac at osgeo.org
Fri May 16 11:52:13 PDT 2025
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.2.9
Component: postgis | Version: 3.4.x
Keywords: |
As mentioned in https://lists.osgeo.org/pipermail/postgis-
devel/2025-May/030532.html if a user uses a spatial ref sys other than
4326 for geography type, restore might fail.
Example from mail list thread
Here is the SQL sequence that yields an error (shared by one of our
engineers)
CREATE SCHEMA procsch;
CREATE TABLE "procsch"."MyTab" (
"id" bigint,
"loc" "public"."geography"(Point,4283)
INSERT INTO procsch.MyTab VALUES (1, ST_GeomFromText('POINT(152.138672
-30.689888)', 4283));
$ strings /PATH/bin/pg_dump | grep POSTGIS_spatial
POSTGIS_spatial_ref_sys
/PATH/bin/initdb -D /srv/13/data/pg_data
/PATH11/bin/pg_ctl -D /srv/11/data/pg_data -l logfile stop
/PATH/bin/pg_upgrade --check --link --old-datadir=/srv/11/data/pg_data
--new-datadir=/srv/13/data/pg_data --old-bindir=/PATH11/bin
--new-bindir=/PATH/bin --old-port=5432 --new-port=5434
# for real, no --check:
/PATH/bin/pg_upgrade --link --old-datadir=/srv/11/data/pg_data
And it did blow up with :
pg_restore: creating TABLE "procsch.MyTab"
pg_restore: while PROCESSING TOC:
pg_restore: from TOC entry 371; 1259 17425 TABLE MyTab u1
pg_restore: error: could not execute query: ERROR: relation
"public.spatial_ref_sys" does not exist
LINE 21: "loc" "public"."geography"(Point,4283)
QUERY: SELECT proj4text, auth_name, auth_srid, srtext FROM
public.spatial_ref_sys WHERE srid = 4283 LIMIT 1
"id" bigint,
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5899>
