[PostGIS] #5899: pg_upgrade fails restore geography because spatial_ref_sys does not exist
trac at osgeo.org
Fri May 16 13:52:45 PDT 2025
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.2.9
Component: postgis | Version: 3.4.x
Resolution: | Keywords:
Comment (by robe):
I think the failure is happening here -
https://git.osgeo.org/gitea/postgis/postgis/src/branch/master/postgis/gserialized_typmod.c#L344
call to srid_check_latlong
I'm thinking some of these possible solutions:
1) Any spatial_ref_sys check should confirm the table exists and is not
empty otherwise just return success with a warning. This would also take
care of those situations where people are using ST_Transform on their
indexes or have check constraints checking spatial_ref_sys and pg_upgrade
doesn't create spatial_ref_sys or populate spatial_ref_sys before trying
to load user data.
2) Change srid_check_latlong, to hard-code some common known long lats (or
read from proj.db) and check against that before resorting to reading
spatial ref sys.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5899#comment:1>
