[SCM] PostGIS branch master updated. 3.5.0-346-g3ffd80960
Mon May 26 15:53:03 PDT 2025
the project "PostGIS".
       via  3ffd809608397179c63488f552787caf20783101 (commit)
      from  8f6a9d194e902de416f8fe520090dd41f019125c (commit)
revisions in full, below.
commit 3ffd809608397179c63488f552787caf20783101
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Mon May 26 15:52:58 2025 -0700
    Improve doc raster reference preamble
diff --git a/doc/reference_raster.xml b/doc/reference_raster.xml
index a4c4b2653..d73950455 100644
--- a/doc/reference_raster.xml
+++ b/doc/reference_raster.xml
@@ -2,14 +2,11 @@
 <chapter xmlns:xlink="http://www.w3.org/1999/xlink" xmlns="http://docbook.org/ns/docbook" version="5.0" xml:id="RT_reference">
   <title>Raster Reference</title>
-  <para>The functions given below are the ones which a user of PostGIS Raster is
-  likely to need and which are currently available in PostGIS Raster. There are other functions which are required support
-  functions to the raster objects which are not of use to a general
-  user.</para>
-  <para><varname>raster</varname> is a new PostGIS type for storing and analyzing raster data. </para>
+  <para><varname>raster</varname> is a PostGIS type for storing and analyzing raster data. </para>
   <para>For loading rasters from raster files please refer to <xref linkend="RT_Loading_Rasters"/></para>
-    <para>For the examples in this reference we will be using a raster table of dummy rasters - Formed with the following code </para>
+    <para>Some examples in this reference use a raster table of dummy data,
+    created with the following code:</para>
 <programlisting language="sql">CREATE TABLE dummy_rast(rid integer, rast raster);
 INSERT INTO dummy_rast(rid, rast)
 VALUES (1,
@@ -42,6 +39,11 @@ VALUES (1,
 (2,  ('01000003009A9999999999A93F9A9999999999A9BF000000E02B274A' ||
 '41000000007719564100000000000000000000000000000000FFFFFFFF050005000400FDFEFDFEFEFDFEFEFDF9FAFEF' ||
 'EFCF9FBFDFEFEFDFCFAFEFEFE04004E627AADD16076B4F9FE6370A9F5FE59637AB0E54F58617087040046566487A1506CA2E3FA5A6CAFFBFE4D566DA4CB3E454C5665')::raster);</programlisting>
+  <para>The functions below are ones which a user of PostGIS Raster is likely to need.
+  There are other raster support functions which are not of interest to a general
+  user.</para>
   <section xml:id="Raster_Types">
     <title>Raster Support Data types</title><info>
             <abstract>
Summary of changes:
 doc/reference_raster.xml | 14 ++++++++------
 1 file changed, 8 insertions(+), 6 deletions(-)
hooks/post-receive
