[SCM] PostGIS branch master updated. 3.5.0-347-gcf9f71e95
Mon May 26 22:19:31 PDT 2025
the project "PostGIS".
       via  cf9f71e95707cde65e208b074d80d0b53af04e50 (commit)
      from  3ffd809608397179c63488f552787caf20783101 (commit)
revisions in full, below.
commit cf9f71e95707cde65e208b074d80d0b53af04e50
Author: Regina Obe <lr at pcorp.us>
Date:   Tue May 27 01:19:20 2025 -0400
    Turn back on topology testing for winnie, and update versions of libs
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index 07b23e47e..003c6d16b 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -58,7 +58,7 @@ fi
 sh autogen.sh
 # excluding topology cause it's erroring out on some tests
-EXTRA_CONFIGURE_ARGS="${EXTRA_CONFIGURE_ARGS} --without-topology"
+#EXTRA_CONFIGURE_ARGS="${EXTRA_CONFIGURE_ARGS} --without-topology"
 if [ -n "$PCRE_VER" ]; then
     export PATH="${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
diff --git a/ci/winnie/winnie_common.sh b/ci/winnie/winnie_common.sh
index 8b5925fee..b629ce201 100644
--- a/ci/winnie/winnie_common.sh
+++ b/ci/winnie/winnie_common.sh
@@ -12,11 +12,11 @@ export MSYS2_ARG_CONV_EXCL=/config/tags
 export XML_CATALOG_FILES="/projects/docbook/docbook-5.0.1/catalog.xml"
 if  [[ "${OVERRIDE}" == '' ]] ; then
-	export GEOS_VER=3.13.0
+	export GEOS_VER=3.13.1
 	export GDAL_VER=3.9.2
 	export PROJ_VER=8.2.1
-	export SFCGAL_VER=1.5.2
-	export CGAL_VER=5.6.1
+	export SFCGAL_VER=2.1.0
+	export CGAL_VER=6.0.1
 	export ICON_VER=1.17
 	export ZLIB_VER=1.2.13
 	export PROTOBUF_VER=3.2.0
@@ -65,11 +65,11 @@ fi;
 #set to something even if override is on but not set
 if  [[ "${CGAL_VER}" == '' ]] ; then
 fi;
 ##hard code versions of cgal etc. for now
-export CGAL_VER=5.6.1
 BOOST_VER=1.84.0
 export BOOST_VER_WU=1_84_0
Summary of changes:
 ci/winnie/regress_postgis.sh |  2 +-
 ci/winnie/winnie_common.sh   | 10 +++++-----
 2 files changed, 6 insertions(+), 6 deletions(-)
hooks/post-receive
