[PostGIS] #5905: Server crashes when input geometries with excessive nesting are passed to ST_DumpPoints or ST_DumpSegments
PostGIS trac at osgeo.org
Tue May 27 19:32:29 PDT 2025
 Reporter:  dmyzl                                |      Owner:  pramsey
     Type:  defect                               |     Status:  new
 Priority:  medium                               |  Milestone:  PostGIS
                                                 |  3.5.3
Component:  postgis                              |    Version:  3.5.x
 Keywords:  ST_DumpPoints ST_DumpSegments crash  |
 The server crashes when executing the following SQL statement:
 select geom_dump.path,st_asewkt(geom_dump.geom) from
 ST_DumpPoints(ST_GeomFromText('geometrycollection(geometrycollection(
 geometrycollection(geometrycollection(geometrycollection(geometrycollection(geometrycollection(geometrycollection(geometrycollection(geometrycollection(geometrycollection(geometrycollection(
 geometrycollection(multipoint empty,point(0 0), multilinestring empty,
 multilinestring((0 0, 1 1 ),(1 1, 2
 2)))))))))))))))))))))))))))))))))))',4269)) as geom_dump;
 ST_DumpSegments(ST_GeomFromText('geometrycollection(geometrycollection(
 postgis_full_version:
 POSTGIS="3.5.3 0" [EXTENSION] PGSQL="170" GEOS="3.13.1-CAPI-1.19.2"
 SFCGAL="SFCGAL 1.5.0, CGAL 5.6, BOOST 1.74.0" PROJ="9.3.1
 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
 USER_WRITABLE_DIRECTORY=/home/yzl/.local/share/proj
 DATABASE_PATH=/home/yzl/project/build_pg_postgis/proj-9.3.1/tmp_install/share/proj/proj.db"
 (compiled against PROJ 9.3.1) GDAL="GDAL 3.7.2, released 2023/09/05"
 LIBXML="2.9.13" LIBJSON="0.17" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
 (Internal)" (core procs from "3.5.2 dea6d0a" need upgrade) TOPOLOGY
 (topology procs from "3.5.2 dea6d0a" need upgrade) RASTER (raster procs
 from "3.5.2 dea6d0a" need upgrade) (sfcgal procs from "3.5.2 dea6d0a" need
 upgrade)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5905>
