[PostGIS] #5905: Server crashes when input geometries with excessive nesting are passed to ST_DumpPoints or ST_DumpSegments
trac at osgeo.org
Tue May 27 22:46:45 PDT 2025
Reporter: dmyzl | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.5.4
Component: postgis | Version: 3.5.x
Resolution: | Keywords: ST_DumpPoints ST_DumpSegments crash
Changes (by robe):
* priority: medium => blocker
Comment:
Confirmed on PostgreSQL 17.2 (Ubuntu 17.2-1.pgdg24.04+1) on x86_64-pc-
linux-gnu, compiled by gcc (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0, 64-bit
POSTGIS="3.5.1 48ab069" [EXTENSION] PGSQL="170" GEOS="3.12.1-CAPI-1.18.1"
SFCGAL="SFCGAL 1.5.1, CGAL 5.6, BOOST 1.83.0" PROJ="9.4.0
NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/tmp/proj DATABASE_PATH=/usr/share/proj/proj.db"
(compiled against PROJ 9.4.0) GDAL="GDAL 3.8.4, released 2024/02/08"
LIBXML="2.9.14" LIBJSON="0.17" LIBPROTOBUF="1.4.1" WAGYU="0.5.0
(Internal)" RASTER
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5905#comment:3>
