[PostGIS] #5906: Server crashes when densifyFrac is set too low in ST_FrechetDistance
PostGIS trac at osgeo.org
Tue May 27 19:45:50 PDT 2025
 Reporter:  dmyzl                     |      Owner:  pramsey
     Type:  defect                    |     Status:  new
 Priority:  medium                    |  Milestone:  PostGIS 3.5.3
Component:  postgis                   |    Version:  3.5.x
 Keywords:  ST_FrechetDistance crash  |
 The server crashes when executing the following SQL statement:
 SELECT st_frechetdistance(ST_GeomFromText('LINESTRING (1 0, 2 0)'),
 ST_GeomFromText('LINESTRING (-1 0,0 0,7 8)'), 0.0001);
 postgis_full_version:
 POSTGIS="3.5.3 0" [EXTENSION] PGSQL="170" GEOS="3.13.1-CAPI-1.19.2"
 SFCGAL="SFCGAL 1.5.0, CGAL 5.6, BOOST 1.74.0" PROJ="9.3.1
 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
 USER_WRITABLE_DIRECTORY=/home/yzl/.local/share/proj
 DATABASE_PATH=/home/yzl/project/build_pg_postgis/proj-9.3.1/tmp_install/share/proj/proj.db"
 (compiled against PROJ 9.3.1) GDAL="GDAL 3.7.2, released 2023/09/05"
 LIBXML="2.9.13" LIBJSON="0.17" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
 (Internal)" (core procs from "3.5.2 dea6d0a" need upgrade) TOPOLOGY
 (topology procs from "3.5.2 dea6d0a" need upgrade) RASTER (raster procs
 from "3.5.2 dea6d0a" need upgrade) (sfcgal procs from "3.5.2 dea6d0a" need
 upgrade)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5906>
