[PostGIS] #5909: Server crashes when ST_ValueCount is called with table and column names but the table is empty
PostGIS trac at osgeo.org
Tue May 27 22:35:12 PDT 2025
the table is empty
  Reporter:  dmyzl    |      Owner:  robe
      Type:  defect   |     Status:  new
  Priority:  blocker  |  Milestone:  PostGIS 3.5.4
 Component:  raster   |    Version:  3.5.x
Resolution:           |   Keywords:
Changes (by robe):
 * priority:  medium => blocker
Comment:
 Confirm it crashes on 3.6.0dev too.
 PostgreSQL 18beta1 on x86_64-w64-mingw32, compiled by gcc.exe (Rev5, Built
 by MSYS2 project) 13.2.0, 64-bit POSTGIS="3.6.0dev 3.5.0-346-g3ffd80960"
 [EXTENSION] PGSQL="180" GEOS="3.14.0dev-CAPI-1.20.0" PROJ="8.2.1
 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
 USER_WRITABLE_DIRECTORY=C:\Users\lr\AppData\Local/proj
 DATABASE_PATH=C:\ming64\projects\proj\rel-
 proj-8.2.1w64/share/proj/proj.db" (compiled against PROJ 8.2.1) GDAL="GDAL
 3.9.2, released 2024/08/13" LIBXML="2.12.5" LIBPROTOBUF="1.2.1"
 WAGYU="0.5.0 (Internal)" RASTER
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5909#comment:2>
