[PostGIS] #5909: Server crashes when ST_ValueCount is called with table and column names but the table is empty
trac at osgeo.org
Tue May 27 22:38:26 PDT 2025
the table is empty
Reporter: dmyzl | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.5.4
Component: raster | Version: 3.5.x
Resolution: | Keywords:
Comment (by robe):
Also crashes on
PostgreSQL 17.2 on x86_64-windows, compiled by msvc-19.42.34435, 64-bit
POSTGIS="3.5.2 3.5.2" [EXTENSION] PGSQL="170" GEOS="3.13.0-CAPI-1.19.0"
SFCGAL="SFCGAL 1.5.2, CGAL 5.6.1, BOOST 1.84.0" PROJ="8.2.1
NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=C:\Windows\ServiceProfiles\NetworkService\AppData\Local/proj
DATABASE_PATH=C:\Program
Files\PostgreSQL\17\share\contrib\postgis-3.5\proj\proj.db" (compiled
against PROJ 8.2.1) GDAL="GDAL 3.9.2, released 2024/08/13" LIBXML="2.12.5"
LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.5.0 (Internal)" TOPOLOGY
RASTER
and
PostgreSQL 17.2 (Ubuntu 17.2-1.pgdg24.04+1) on x86_64-pc-linux-gnu,
compiled by gcc (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0, 64-bit
POSTGIS="3.5.1 48ab069" [EXTENSION] PGSQL="170" GEOS="3.12.1-CAPI-1.18.1"
SFCGAL="SFCGAL 1.5.1, CGAL 5.6, BOOST 1.83.0" PROJ="9.4.0
USER_WRITABLE_DIRECTORY=/tmp/proj DATABASE_PATH=/usr/share/proj/proj.db"
(compiled against PROJ 9.4.0) GDAL="GDAL 3.8.4, released 2024/02/08"
LIBXML="2.9.14" LIBJSON="0.17" LIBPROTOBUF="1.4.1" WAGYU="0.5.0
(Internal)" RASTER
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5909#comment:3>
