[PostGIS] #5908: Server crashes when GetFaceContainingPoint is called with NULL arguments
    trac at osgeo.org
    Tue May 27 22:50:12 PDT 2025
  Reporter:  dmyzl     |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  blocker   |  Milestone:  PostGIS 3.5.4
 Component:  topology  |    Version:  3.5.x
Resolution:            |   Keywords:
Changes (by robe):
 * component:  postgis => topology
 * owner:  pramsey => strk
 * priority:  medium => blocker
Comment:
 confirmed on:
 PostgreSQL 17.2 (Ubuntu 17.2-1.pgdg24.04+1) on x86_64-pc-linux-gnu,
 compiled by gcc (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0, 64-bit
 POSTGIS="3.5.1 48ab069" [EXTENSION] PGSQL="170" GEOS="3.12.1-CAPI-1.18.1"
 SFCGAL="SFCGAL 1.5.1, CGAL 5.6, BOOST 1.83.0" PROJ="9.4.0
 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
 USER_WRITABLE_DIRECTORY=/tmp/proj DATABASE_PATH=/usr/share/proj/proj.db"
 (compiled against PROJ 9.4.0) GDAL="GDAL 3.8.4, released 2024/02/08"
 LIBXML="2.9.14" LIBJSON="0.17" LIBPROTOBUF="1.4.1" WAGYU="0.5.0
 (Internal)" TOPOLOGY RASTER
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5908#comment:3>
