[PostGIS] #5908: Server crashes when GetFaceContainingPoint is called with NULL arguments
trac at osgeo.org
Tue May 27 20:27:22 PDT 2025
Reporter: dmyzl | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.3
Component: postgis | Version: 3.5.x
Keywords: |
The server crashes when executing the following SQL statement:
select topology.GetFaceContainingPoint(NULL, NULL);
select topology.GetFaceContainingPoint(NULL, st_point(0, 0));
postgis_full_version:
POSTGIS="3.5.3 0" [EXTENSION] PGSQL="170" GEOS="3.13.1-CAPI-1.19.2"
SFCGAL="SFCGAL 1.5.0, CGAL 5.6, BOOST 1.74.0" PROJ="9.3.1
NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/home/yzl/.local/share/proj
DATABASE_PATH=/home/yzl/project/build_pg_postgis/proj-9.3.1/tmp_install/share/proj/proj.db"
(compiled against PROJ 9.3.1) GDAL="GDAL 3.7.2, released 2023/09/05"
LIBXML="2.9.13" LIBJSON="0.17" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
(Internal)" (core procs from "3.5.2 dea6d0a" need upgrade) TOPOLOGY
(topology procs from "3.5.2 dea6d0a" need upgrade) RASTER (raster procs
from "3.5.2 dea6d0a" need upgrade) (sfcgal procs from "3.5.2 dea6d0a" need
upgrade)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5908>
