[PostGIS] #5907: Server crashes when TopoGeo_AddPolygon is called with POLYGON EMPTY
trac at osgeo.org
Thu May 29 01:12:24 PDT 2025
Reporter: dmyzl | Owner: strk
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 3.0.12
Component: topology | Version: 3.0.x
Resolution: fixed | Keywords: TopoGeo_AddPolygon crash
Changes (by Sandro Santilli <strk@…>):
* resolution: => fixed
* status: assigned => closed
Comment:
In [changeset:"d40d7a73958fbbbc2819737ce1f846f8fb7122c2/git" d40d7a7/git]:
{{{#!CommitTicketReference repository="git"
revision="d40d7a73958fbbbc2819737ce1f846f8fb7122c2"
Fix crash in TopoGeo_AddPolygon
Closes #5907 in 3.0 branch (3.0.12dev)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5907#comment:11>
