[SCM] PostGIS branch stable-3.5 updated. 3.5.3-3-gcffcdca91
git at osgeo.org
git at osgeo.org
Tue May 27 23:06:15 PDT 2025
the project "PostGIS".
The branch, stable-3.5 has been updated
via cffcdca91556caf2cf265fbc908254e23ab29021 (commit)
from 7f64ebbe2ecb75f0bd2a0c528652ec77950e9923 (commit)
revisions in full, below.
commit cffcdca91556caf2cf265fbc908254e23ab29021
Author: Regina Obe <lr at pcorp.us>
Date: Wed May 28 02:06:03 2025 -0400
Turn back on winnie topology testing and run make in parallel
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index 68bb41988..19d49335e 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -58,7 +58,7 @@ fi
sh autogen.sh
# excluding topology cause it's erroring out on some tests
-EXTRA_CONFIGURE_ARGS="${EXTRA_CONFIGURE_ARGS} --without-topology"
+#EXTRA_CONFIGURE_ARGS="${EXTRA_CONFIGURE_ARGS} --without-topology"
if [ -n "$PCRE_VER" ]; then
export PATH="${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
@@ -91,7 +91,7 @@ LDFLAGS="-Wl,--enable-auto-import -L${PGPATH}/lib -L${LZ4_PATH}/lib -L${PROJECTS
#patch liblwgeom generated make to get rid of dynamic linking
#sed -i 's/LDFLAGS += -no-undefined//g' liblwgeom/Makefile
-make
+make -j 4
make install
make check RUNTESTFLAGS=-v
@@ -103,7 +103,7 @@ if [ "$MAKE_EXTENSION" == "1" ]; then
strip postgis/postgis-*.dll
strip raster/rt_pg/postgis_raster-*.dll
strip sfcgal/*.dll
- #cp topology/*.dll ${PGPATHEDB}/lib
+ cp topology/*.dll ${PGPATHEDB}/lib
cp postgis/postgis*.dll ${PGPATHEDB}/lib
cp sfcgal/*.dll ${PGPATHEDB}/lib
cp raster/rt_pg/postgis_raster-*.dll ${PGPATHEDB}/lib
@@ -120,7 +120,7 @@ value=${value//UPGRADEABLE_VERSIONS = /}
export UPGRADEABLE_VERSIONS=$value
export WIN_RELEASED_VERSIONS="2.0.0 2.0.1 2.0.3 2.0.4 2.0.6 2.1.4 2.1.7 2.1.8 2.2.0 2.2.3 2.3.0 2.3.7 2.4.0 2.4.4"
#echo "Versions are: $UPGRADEABLE_VERSIONS"
-for EXTNAME in postgis postgis_raster postgis_sfcgal postgis_tiger_geocoder address_standardizer; do
+for EXTNAME in postgis postgis_raster postgis_sfcgal postgis_tiger_geocoder address_standardizer postgis_topology; do
cp extensions/$EXTNAME/sql/* ${PGPATHEDB}/share/extension
cp extensions/$EXTNAME/sql/$EXTNAME--TEMPLATED--TO--ANY.sql ${PGPATHEDB}/share/extension/$EXTNAME--$POSTGIS_MICRO_VER--${POSTGIS_MINOR_MAX_VER}.sql;
Summary of changes:
ci/winnie/regress_postgis.sh | 8 ++++----
1 file changed, 4 insertions(+), 4 deletions(-)
hooks/post-receive
