[PostGIS] #5910: ST_AsBinary, ST_AsEWKB, and ST_AsHEXEWKB return results even when given invalid byte order strings
PostGIS trac at osgeo.org
Tue May 27 23:11:27 PDT 2025
 Reporter:  dmyzl                               |      Owner:  pramsey
     Type:  defect                              |     Status:  new
 Priority:  medium                              |  Milestone:  PostGIS
                                                |  3.5.4
Component:  postgis                             |    Version:  3.5.x
 Keywords:  ST_AsBinary ST_AsEWKB ST_AsHEXEWKB  |
 The functions ST_AsEWKB, ST_AsBinary, and ST_AsHEXEWKB accept an optional
 second argument that specifies the byte order of the output. According to
 the documentation, the valid values are 'XDR' (big endian) and 'NDR'
 (little endian).
 However, I noticed that if other arbitrary strings are passed as the
 second argument, the functions still return a result — and always in
 little-endian order. For example:
 select ST_AsEWKB(ST_GeomFromText( 'point empty' ),'aaaa');
 select ST_AsBinary(ST_GeomFromText( 'point empty' ),'aaaa');
 select ST_AsHEXEWKB(ST_GeomFromText( 'point empty' ),'aaaa');
 I'm not sure whether this behavior is intended, but the documentation
 (https://postgis.net/docs/manual-3.5/ST_AsEWKB.html) does not mention that
 unrecognized values will default to little endian.
 postgis_full_version:
 POSTGIS="3.5.3 0" [EXTENSION] PGSQL="170" GEOS="3.13.1-CAPI-1.19.2"
 SFCGAL="SFCGAL 1.5.0, CGAL 5.6, BOOST 1.74.0" PROJ="9.3.1
 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
 USER_WRITABLE_DIRECTORY=/home/yzl/.local/share/proj
 DATABASE_PATH=/home/yzl/project/build_pg_postgis/proj-9.3.1/tmp_install/share/proj/proj.db"
 (compiled against PROJ 9.3.1) GDAL="GDAL 3.7.2, released 2023/09/05"
 LIBXML="2.9.13" LIBJSON="0.17" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
 (Internal)" (core procs from "3.5.2 dea6d0a" need upgrade) TOPOLOGY
 (topology procs from "3.5.2 dea6d0a" need upgrade) RASTER (raster procs
 from "3.5.2 dea6d0a" need upgrade) (sfcgal procs from "3.5.2 dea6d0a" need
 upgrade)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5910>
