[PostGIS] #5914: Raster function ST_Resample may enter an infinite loop for certain inputs
trac at osgeo.org
Wed May 28 18:56:05 PDT 2025
Reporter: dmyzl | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.4
Component: raster | Version: 3.5.x
Keywords: ST_Resample |
Executing the following SQL with `ST_RESAMPLE` causes PostgreSQL to enter
an extremely long loop — it has been running for over 17 hours without
producing any result:
select ST_RESAMPLE(
ST_RastFromHexWKB('01000003009A9999999999A93F9A9999999999A9BF000000E02B274A4100000000771956410000000000000000000000000000000000000000050005000400FDFEFDFEFEFDFEFEFDF9FAFEFEFCF9FBFDFEFEFDFCFAFEFEFE04004E627AADD16076B4F9FE6370A9F5FE59637AB0E54F58617087040046566487A1506CA2E3FA5A6CAFFBFE4D566DA4CB3E454C5665')
,1,1,1,1,1,1,'NearestNeighbour',1
Unfortunately, I only have the WKB data, the original WKT representation
has been lost.
postgis_full_version:
POSTGIS="3.5.3 0" [EXTENSION] PGSQL="170" GEOS="3.13.1-CAPI-1.19.2"
SFCGAL="SFCGAL 1.5.0, CGAL 5.6, BOOST 1.74.0" PROJ="9.3.1
NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/home/yzl/.local/share/proj
DATABASE_PATH=/home/yzl/project/build_pg_postgis/proj-9.3.1/tmp_install/share/proj/proj.db"
(compiled against PROJ 9.3.1) GDAL="GDAL 3.7.2, released 2023/09/05"
LIBXML="2.9.13" LIBJSON="0.17" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
(Internal)" (core procs from "3.5.2 dea6d0a" need upgrade) TOPOLOGY
(topology procs from "3.5.2 dea6d0a" need upgrade) RASTER (raster procs
from "3.5.2 dea6d0a" need upgrade) (sfcgal procs from "3.5.2 dea6d0a" need
upgrade)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5914>
