[PostGIS] #5915: ST_LineLocatePoint returns incorrect result with Geography input and use_spheroid = false
PostGIS trac at osgeo.org
Wed May 28 19:10:52 PDT 2025
 Reporter:  dmyzl               |      Owner:  pramsey
     Type:  defect              |     Status:  new
 Priority:  medium              |  Milestone:  PostGIS 3.5.4
Component:  postgis             |    Version:  3.5.x
 Keywords:  ST_LineLocatePoint  |
 When passing Geography to `ST_LineLocatePoint`, and setting the third
 parameter to use a standard sphere (`use_spheroid = false`), the function
 returns an incorrect result:
 select ST_LineLocatePoint(ST_GeogFromText('linestring(0 5,0 1,0 -3,0
 -5)'), ST_GeogFromText('point(5 0)'), true);
 -- return: 0.5
 -5)'), ST_GeogFromText('point(5 0)'), false);
 -- return: 0
 postgis_full_version:
 POSTGIS="3.5.3 0" [EXTENSION] PGSQL="170" GEOS="3.13.1-CAPI-1.19.2"
 SFCGAL="SFCGAL 1.5.0, CGAL 5.6, BOOST 1.74.0" PROJ="9.3.1
 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
 USER_WRITABLE_DIRECTORY=/home/yzl/.local/share/proj
 DATABASE_PATH=/home/yzl/project/build_pg_postgis/proj-9.3.1/tmp_install/share/proj/proj.db"
 (compiled against PROJ 9.3.1) GDAL="GDAL 3.7.2, released 2023/09/05"
 LIBXML="2.9.13" LIBJSON="0.17" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
 (Internal)" (core procs from "3.5.2 dea6d0a" need upgrade) TOPOLOGY
 (topology procs from "3.5.2 dea6d0a" need upgrade) RASTER (raster procs
 from "3.5.2 dea6d0a" need upgrade) (sfcgal procs from "3.5.2 dea6d0a" need
 upgrade)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5915>
